Question about Maxi-Cosi Baby Gear
How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
Posted on Nov 02, 2009
Spare parts
Hi
Spare part items can be ordered via your local Maxi-Cosi retailer or direct from the customer care team.
Maxi Cosi Mura 2008 2012 Spare Parts
Oct 10, 2013 | Maxi-Cosi Mura 3 Pushchair
How do I replace the Mura 3 foam grips?
Hi
The foam handlebar cover on the Maxi-Cosi Mura chassis is not designed to be removed.
Aug 31, 2013 | Maxi-Cosi Baby Gear
Difficult to push, needs a service?
If you are in the UK and the Maxi Cosi Mura 3 is under 2 years old please contact your retailer with proof of purchase and they will make arrangements for it to come in to our engineers for inspection / repair work required.
If you are in the UK and the MAxi Cosi Mura 3 is over 2 years old or you no longer have proof of purchase you can book in for chargeable inspection / repair work required by calling the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) Standard cost is 39.99GBP and this does include courier collection and delivery.
If you are not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the "Contact Us" form for your enquiry to be sent through to the customer care team who can help.
May 29, 2013 | Maxi-Cosi Mura 3 Pushchair
Where can i buy a t-bar for my maxi cosi mura 3 pushchair?
Hi
If you are in the UK you can order via your local Maxi Cosi retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 20GBP and if you order direct there is an additional 3.99GBP p+p charge.
If you are not in the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to be sent through to the customer care team in your country who can assist.
Apr 19, 2013 | Maxi-Cosi Mura 3 Pushchair
Can dreami carry cot fit mura 3?
The combination has not been tested or been given the required safety certificates so we must advise that you do NOT use a Quinny Dreami on a Maxi Cosi Mura 3 chassis.
The Maxi Cosi Mura carrycot or 2013 Maxi Cosi Folding Carrycot ONLY should be used on the Mura for guaranteed safe combination.
The use of a Dreami on the Mura chassis has not been approved and we cannot accept liability for any malfunction of the product combination.
Mar 15, 2013 | Maxi-Cosi Mura 3 Pushchair
Handle foam rip
Hi
The handlebar foam of the Maxi Cosi Mura is not available as a seperate spare part item. To replace the foam would mean to replace the handlebar.
If you're in the UK and your Maxi Cosi Mura is under 2 years old please contact your retailer with your proof of purchase for them to make arrangements for it to be sent to our engineers for handlebar replacement.
If you're in the UK and your Maxi Cosi Mura is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to book in for chargeable replacement of the handlebar.
If you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side of the page to get in touch with the customer care team for your country.
Mar 04, 2013 | Maxi-Cosi Mura 3 Pushchair
Will the maxi Cosi Mura carrycot fit my Maxi Cosi loola?
Hi
No the Mura carrycot is for use on the Mura chassis only.
For the Maxi Cosi Loola you need Maxi Cosi carrycot.
Oct 27, 2012 | Maxi-Cosi Loola Stroller
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
I lost my maxi cosi mura 4 hood, where i can find one?
I would suggest that you contact www.maxi-cosi.com who should be able to point you in the right direction.
I hope this helps.
Sep 20, 2009 | Maxi-Cosi Foray Penguin Stroller
Unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
Aug 23, 2009 | Maxi-Cosi Baby Gear
Baby Gear Logo
957 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
