Question about Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 My garmin will not turn on. The last time I used it was fine. Does anyone have any suggestions? I have already changed the fuse.
  • Anonymous Oct 14, 2008
    Same problem here. Mine was working fine, I made no changes to it. As I
    was driving down the road; not even touching it, it shut off. I have
    checked the fuse inside the power connector (which was a royal pain)
    and it is fine. Tried different power sources (different vehicles). I
    have cleaned the contacts at the power cords connection point and
    checked to see that they are connected. I don't know what else to do.
I had a plug in the past warp from being left on the dash in high heat situations. it will warp just enough for the contacts on the plug to not touch when it is slid into the back of hte unit. Check that area.
Posted on Sep 23, 2008
    Scholar:
  • 174 Answers
Is the power connector on the unit fully seated?
Posted on Jun 16, 2008
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
Garmin echomap 50 keeps cutting in and out
Loose or corroded wiring and or connections.
Jul 25, 2013 | Garmin echoMAP 50s with Transducer
I have a garmin street pilot 2720 I bought a garmin nuMaps lifetime product to up date, would like to up date for the 2nd time can't find where to go about this, I have the product key and the...
Log into your account at www.garmin.com by using the myGarmin link.
With the unit connected to the computer go to the myDashboard link.
Your Street Pilot 2720 should show up on the dashboard.
From there you should be able to apply the update.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin StreetPilot 2720 GPS Receiver
Streetpilot 2720 - also no audio
Yes send a message to the support address at Garmin for help I think the fix was removed as it had some incorrect steps
Jul 30, 2009 | Bennett Marine BENNETT DVD GARMIN...
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Searching for satellite but never finds - what is wrong?
I had one like that last year, I found if I lied to it when it asked what state I was in, then it would find the satellites and work fine ... until the next time you turned it on. That one was fixed by installing new v7.2 firmware using Garmin WebUpdater through the USB port.
I've got one right now that won't find the satellites and the firmware trick didn't work. That's all I've got so far. Tom.
Jan 13, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
Garmin Streetpilot 2720
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
Oct 08, 2007 | Garmin StreetPilot c530 GPS Receiver
Shuts off itself
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Sep 03, 2007 | GPS
Garmin StreetPilot 2720 GPS Receiver Logo
91 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
