Question about Canon BubleJet i965 InkJet Printer
Blue printing as pink - Canon BubleJet i965 InkJet Printer
  • peter_shea Sep 28, 2009
    Thanks, SpideRaY. I already tried that, to no avail. I meant to put more detail in my original post, but got sidetracked and pressed enter at the wrong point!
    Interestingly, it only happens when printing using a "photo" setting (ie, telling it that the media is capable of high res printing). If I use "standard" print, then blue prints as blue.
    I wondered if any other users had had this specific problem - my next step will be to take out the print head and soak overnight in alcohol. If that fails, then it's time to recycle the printer (pity, I just bought a set pf inks from Cartridge World).
    FYI, the printer doesn't have a blue nozzle - the inks loaded are cyan, photo cyan, black, yellow, photo magenta and magenta.
  • 687 Answers
I think that your Blue ink jet is blocked or is only working some of the time, try upto 10 cleaning purge processed if it still causes problems then the printer might need a service. This might cost about £50 so it might be worth trading it in for a new one.
Posted on Sep 28, 2009
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Mar 13, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
All color images are printing pink/orange. all inks are only 1% used. the very first photo i printed was beautiful. every photo since has been the pink orange color. even the black is not printing well
This sounds like a blue ink cartridge failure or a clogged blue ink nozzle. If you have cleaned the nozzles, I would try another blue cartridge. if this does not solve the problem more aggressive cleaning may be required. Let me know and we can go throught the process. Thanks.
Apr 21, 2011 | Lexmark Prospect Pro205 Wireless...
My HP printer is printing colours in a pink shade, can you please help.
Printers usually have three PRIMARY colours: YELLOW, PINK, BLUE.
So, if you have no YELLOW or BLUE ink, what's left is PINK.
Sep 17, 2010 | HP Office Equipment & Supplies
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer won't print yellow
Either theyellow is finished or the nozzles are blocked. Try cleaningthe nozzles of the cartridge.
May 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Sep 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon BubleJet i965 InkJet Printer Logo
107 people viewed this question
old marine
old marine
