Question about Amana NTW5100TQ Top Load Washer
Does this washer even have a hot water cycle? There is a hot water hose going in and it is turned on......but how do Iget a hot wash?
  • sharekauai Sep 28, 2009
    I am starting to think this model does not have hot cycle. There is no knob for one on the panel...Have I bought a clunker? Can I get hot water into this washer. It is brand new!
    President:
  • 1,776 Answers
If the hot water is not working, then check the water inlet valve. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the valve. Pay particular attention to the hot water side. Make sure the screens are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter and check for continuity. A lack of continuity will mean a bad solenoid and the assembly will have to be replaced. I'll attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
    Genius:
  • Amana Master
  • 1,474 Answers
Possible faulty hot solonoid valve,, not too expesive to repair
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
Will not advance automatically through cycles. Ha...
I would have thought it was the board too! does it beep when it stops? if it does then it should be putting up a fault code.top row of lights..CHeck that you have both the hot & cold hoses connected & turned on at the taps.even if you are not useing hot water to wash with,turn them both on anyway.Some machines require this regardless of wether you are useing hot.The reason for this is F&P have built into their machines to give a little squirt of hot water to maintain a certain level of cold wash.Make sure also that hot hose is going to hot valve & cold to cold.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Amana NTW5100TQ Top Load Washer Logo
180 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
