Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
What can i do about excessive ice build up in front of the freezer?
  • 832 Answers
1. Unplug the power cord, and allow the ice buildup
to melt.
2. Clean your ref, as well as the condenser.
3. Check the refrigerator thermostat setting. Do not
set it at maximum. Set it at midway between max
and zero.
4. Plug the power cord back, and switch the ref on.
Observe if it does have an excessive ice build up.
Send your e-mail for your comments on this solution
Posted on Sep 28, 2009
Ice in the bottom of the freezer compartment
there should be a drain hole at the bottom of the freezer that goes to a evaporation pan underneath. check to see if the drain is clogged. in areas with high temps and or humidity there will be excessive moisture build up,the more the door is opened the more moisture (condensation). Clear the drain, it may just be blocked by ice, MAKE SURE THE UNIT IS LEVEL! This will let the moisture drain properly and prevent ice build up.
Apr 11, 2014 | Freezers
Cracking sounds from top of refrigerator compartment of a 7 year old WSE6070WA
Had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Oct 20, 2013 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Refrigerator is not working, the fridge is warm, and the freezer is running well, how can i fix the problem
You need to check the freezer compartment for excess ice build up on the evaporator coil.
also check and see if the evaporator fan is running.
while the unit is in a cooling. if the fan is not running then you need to replace it.
If there is excess ice build up then you can use a hair dryer and defrost the coil there could be a problem witht he defrost circuit.
Mar 12, 2010 | Refrigerators
Ice builds up and closes off the vents in the freezer section. I have "dfrosted" this 3 times in the past 3 months, and it is building up again. Is there a drain tube or something I can check
Try changing the tempt on the freezer, and not have it at the lowest setting. Also, if you do not keep too much items in the freezer, that can contribute to the excessive build-up of ice. Try recommended settings first.
Feb 04, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
No cooling in refridgerator
is freezer cooling?
a possible cause is build up of ice on the evaporator. take off the back panel in the freezer and check. also check the fan is working. if there is excessive ice build up, this can mean that the defrost system is not working. in any case, if there is ice build-up, carefully melt the ice off with a hairdryer
Jun 19, 2008 | Samsung RB215LASH
Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 20, 2008 | Refrigerators
Just found a huge leak
water in pan should evaporate of its own accord. you may have two faults. first, check door seals to see they mate with cabinet. if seals don't seal properly, excessive air will get in and hence the excess of ice. second, you should not have ice build up. remove back panel of freezer and check if evaporator has excessive ice build-up. if so, this points to a fault in the defrost system
Jul 20, 2007 | Viking DFSB483 Side by Side Refrigerator
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
