SOURCE: F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
SOURCE: Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
SOURCE: Error Code F1 on oven timer panel
These ovens have a internal reset feature on them that resets the control memory program
So if you disconnect the power to the oven for at least 1 hr this will also reset the memory program this is very helpful if your door has been locked because of the cleaning program being interupted and the door will not open ok?
