Question about Philips Magnavox MPD845
Magnavox MPD850 Doesn't turn ON,Seems One IC burnt !
IC Has following marking Code.
4801 BA6R1S (8 PIN SOIC)
Can any one suggest its Manufacturers part Number other wise alternate part for it ?
Mine too...
Posted on Mar 09, 2008
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
How do set the timing on hyundai excel 1998
It seems you are encountering problems trying to set the timing marks in your elantra,not to worry,simply follow the stepwise solution below;
Ensure timing marks aligned [6] & [7] .
STEP 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets.
STEP 2. Slacken tensioner pulley bolt [8].Push tensioner pulley firmly against timing belt to tension belt.
STEP 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm.
STEP 4. Except Matrix: Turn crankshaft one turn clockwise.
STEP 5. Matrix: Turn crankshaft two turns clockwise.
STEP 6. Ensure timing marks aligned [6] .
STEP 7. Apply a load of 2 kg to belt at .Belt should deflect 4-6 mm. If not Adjust position of tensioner pulley.
STEP 8. Install components in reverse order of removal.
STEP 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
(7) is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head (6) is crank timing mark,pin mark on crank lines up with markS on block.
Good luck.
Aug 20, 2010 | Hyundai Excel Cars & Trucks
Burned IC on intel D865PERL
see if this link might help you.. might have to hunt for it a bit.. but still worth a try
http://www.hls-systems.com/html/D865PERL.htm
Aug 14, 2009 | Computers & Internet
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox MPD850 DVD Player Doesn't turn ON
Many people buy electronics and never read the manual.
The first thing to do before operating an electronic device is to
read the manual, is for the best. I have had this unit for two years now
and have no problems with it. The most commond mistake people make
with this portable DVD is that they plug in the lighter without removing
the battery. You can't charge the battery with the lighter adapter and
you must remove the battery before you turn it on.
Dec 18, 2007 | Philips Magnavox MPD845
Philips Magnavox MPD845 Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
