Question about Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058
I bought a used miller spectrum 625, can put on
I bought a used miller spectrum 625, I can strike the flame on but it extinguishes quickly, the air compressor pressure is correct, workpiece distance, holding angles, etc what could be the cause of flame dying out?
    Problem Solver:
  • 18 Answers
The consumables on the torch head could be incorrect or not installed correctly. check these.
Posted on Oct 07, 2009
Has cup fault
Check connections on holder and at the main unit. blow out the unit with air to eliminate conductive dust as being a problem. Also make sure cup seating area is clean.
Jan 11, 2012 | Spectrum Miller 625 Xtreme Plasma Cutter...
Miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Hola buen dia necesito que alguien me ayude respecto a una pza de la targeta electronica de la maquina spectrum 625 numero de parte es el siguiente IOR CO621V SA55BA60 . la pza que necesito...
Hola Erick:
Yo te puedo ayudar a conseguirla. Checa el link del diagrama de partes y dime que numero de parte es de acuerdo al diagrama.
http://www.millerwelds.com/om/t2239c_pt_mil.pdf
El numero que pones es el numero de la tarjeta y no lo puedo localizar. asi.
saludos.
Jun 13, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Im looking for a miller spectrum 1251, where can i find one?
I have a miller spectrum 1251 for sale. We moved to a different shop that doesn't have three phase, but the machine has only been used a couple of times. You can reach me at 660-229-0171 if you are interested.
Sep 17, 2010 | Miller SPECTRUM 1251 907305-01-1 PLASMA...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Cant get it to arc or blow?
cant get the plasma to give me a continous arc
Mar 17, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058 Logo
824 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
