Question about Microsoft Xbox 360 Console
Xbox360 My xbox 360 has 3 flashing red light how can I fix it
My console of xbox when I ignite mark a mistake 68
Posted on Dec 18, 2007
XBOX360 FLASHING RED
To fix the flashing red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Nov 05, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
Need a fix for 3 red lights on xbox360
Can't fix it yourself unfortunately. It is a hardware issue. This company can fix it for you.
http://www.nexicore.com/xbox/index.html
Nov 19, 2009 | Microsoft Xbox 360 Console
Red flashing lights ,3 flashing red lights ,when we turn it on.
this looks like a useful page to diagnose your problem:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Oct 29, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red Flashing lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
Xbox360 3 red lights
YOu are having problems with the three red lights right (red ring of death)? How old is your xbox?
Dec 12, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
My xbox 360 not on ,its flash red light
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
