Question about Whirlpool Refrigerators
Whirlpool refrigerator is making a beep noise about every 5 minutes - freezer no longer keeps food frozen. Lights in the house dims with the sound of the beep of the refrigerator - can you tell me what is wrong?
  • John Broderick May 11, 2010
    Hi, It sounds like the compressor is drawing too much power if your lights go dim. I assume your lights are ok when your fridge is unplugged? You need to see if the compressor is running and go from there. Hope this helps
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
BIKER T
  • 909 Answers
SOURCE: whirlpool refrigerator making noise
YOU HAVE AN ISSUE WITH THE DEFROST CIRCUIT. NORMALLY BOTH THE DEFROST COMPONENTS NEED TO BE REPLACED. NOT OFTEN DOES THE DEFROST TIMER GIVE TROUBLE SO IF BOTH COMPONENTS ARE REPLACED AND ELEMENT IS GOOD BUT ICE STILL BUILDS UP THEN TIMER WILL HAVE TO BE REPLACED AS WELL.
Posted on Aug 24, 2007
IFIXALL
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
docjohn174
  • 943 Answers
SOURCE: freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer noise and defrosting
You need to contact a repair shop ASAP.
May 01, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
Jun 09, 2008 | Whirlpool Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
236 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
