Question about Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix S9000 battery change clears date/time.
Everytime I change the AA batteries in my Fuji FinePix S9000, I must reset the time and date, even if the camera was without batteries for only 15 seconds. Is there an internal battery/capacitor that needs to be changed?
  • 3 Answers
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Posted on Oct 13, 2009
    President:
  • 1,187 Answers
It has a 6-hour capacitor to hold the settings.
It is not user replaceable. See page 16 of your manual.
Before removing the batteries, make sure the camera is OFF or the cap will discharge.
It may be as bad a hassle, but if the ac adapter is connected while you change the batteries, the settings will keep.
Posted on Sep 28, 2009
Testimonial: "Great response. Very helpful. Thank you very much. "
Why do I lose date/time on Fuji FinePix S6500 digital camera when I change batteries
You lose the date/time because the camera has no power to it to keep the settings. Basically don't leave the batteries out if you want it to keep the date/time. On the other hand it will just sit and run the batteries down just sitting there off. It is a bit annoying but that's why. Most cameras store an internal charge so they can keep the date/time but it is not supposed to last very long, it was designed so you could swap out dead batteries without having to reset the time/date every time. If it is happening on simple battery changes it means something may be wrong with the camera.
May 17, 2011 | Fuji Finepix A510 Digital Camera
My finepix s9000 will not turn on, it clicks a few times and then there is no power on screens or other features
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
Jul 09, 2010 | Fuji FinePix S9000 Zoom Digital Camera
Every time I replace the 4 AA batteries all camera
There is an internal battery back up for storing settings. It's soldered to the main board and I don't think it's a rechargeable battery judging by the amount of people who have owned these cameras who have encountered the same problem.
It's a watch type battery and these things do go flat after a few years and unless you know the type and voltage only fuji service centres can replace.
It won't affect the camera's performance it's just a pain having to set up each time you change the batteries.
Jan 18, 2010 | Fuji Rod Repair Kit
Finepix S9500 keeps clearing preset settings
The on board memory battery is flat. This is usually a watch battery type which is soldered to the board
Nov 29, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Loss of date and time on battery change
This is not a solution, however I have the very same problem, and as previously described, the problem have started recently after about two years. What make me think that there is an additional internal battery which died, similar to a PC battery that keeps the date and some other stuff
Oct 21, 2009 | Fuji Finepix S6500FD Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Fuji finepic 2650 time date
I have to change my time/date everytime I change the batteries...sorry!
Nov 11, 2007 | Fuji FinePix 2650 Digital Camera
FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
Jun 20, 2007 | Fuji FinePix S9000 Zoom Digital Camera
Fuji FinePix S5000 stuck in date/Time mode
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
Jun 08, 2007 | Fuji FinePix S5000 Digital Camera
Open Questions:
Fuji FinePix S9000 Zoom Digital Camera Logo
1,063 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
