My samsung dvd-vr350m keeps saying dics cannot be recordered or played even samsungs own brand discs
  • 438 Answers
Check ur player...i guess it has the error made during reading...probably clean the reading lens thro lens cleaner solution available
Posted on Sep 28, 2009
After recording the shows into dvd, this dvd cannot be read in other players or PC
Greetings Carl - There are several possibilities, one being that you are using incompatible discs (DVD+R instead if DVD-R as required). The other is that this player is well known for being finicky about even discs of the right type (see above), working well with some brands, so-so with other brands and not at all with still others.
The most likely thing I suspect is that after recording material you are not finalizing the discs. If they're not finalized they will only play on the Samsung and not other devices. This is demonstrated on page 84 of the user manual:
Regards,
Mikeywaf
May 29, 2011 | Samsung DVDR120 DVD Recorder
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Samsung dvd vr-357; recorded DVD only plays on the player
You have to "Finalize" the disc before it will play on other units. Go to Disc Menu, Second choice listed(not in front of it right now) Selections to right will offer disc Finalize. Say YES.
Jul 19, 2009 | Samsung DVD-VR357
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
Unfinalized DVDs
What sort of "recognization" is your TV showing? Do you get a blue screen but no AV?...accordianman
Jan 15, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
