Question about Casio EXILIM Card EX-S770 Digital Camera
Camera wont charge. when camera placed on cradle, the red charge light comes on for about 5 seconds, then starts to flash.the camera does not seem to have any power to it at all.Any ideas????
  • 438 Answers
Battery problem?
Posted on Sep 28, 2009
I have a logitech cordless mouse that does not charge when placed
either ur cradle or ur battery hav been damaged...
try changin it...
Mar 11, 2010 | Computers & Internet
Put camera in cradle to charge. red light comes on for about 5 secs, then goes out. can't get camera to take a charge...
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
Oct 15, 2009 | Sanyo Xacti VCP-HD2 Camcorder
well have you made sure that the wire is fulley connected to the cradle? if it isnt, push hard and connect it back in. if it doesnt work, I have no idea sorry lol =)
Oct 10, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
Oct 24, 2008 | Samsung NV10 Digital Camera
EX S880 not charging
you have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
Aug 05, 2008 | Casio Exilim EX-S880 Digital Camera
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
Flashing Red LED charging light
You can salvage your old battery. Sounds crazy but you can take a 9 volt battery and jumper it to the old battery . It will put enough charge in the np-20 to make it start charging in the cradle. Takes about 20 seconds.. make sure you go + to + .. the size of the 9 volt fits perfectly.
Sep 18, 2007 | Casio Exilim EX-S600 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
121 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
