Question about Epson LX-300 Matrix Printer
Printing on a customise continuose paper
After printing on the first sheet it then prints on the middle of the second paper.it does not move back the paper to the top of the next sheet .How do i set the lx300 to print on the top on the second paper.give steps to do it.
  • 84 Answers
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Posted on Feb 11, 2010
I want to print about 20 documents and send the order to printer to do that ,continiously, and paper feed roller always pick up 3 or four sheets at the same time. When I put to print sheet by sheet it...
First off, I would fan the fan the paper (20) sheets without wrinkling them and second,...I would check your print settings to make sure they are set on Normal and not Quick Print.
You can check this by going to Start, Control Panel, Printers,...click on your printer, select properties, check your print speed there.
Need further assistance, please reply back!
Have a Great Day!
Martie
Sep 15, 2011 | Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
    I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
    To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
    Apr 27, 2011 | Office Equipment & Supplies
    Suddenly HPJ4580 has stopped printing - when pressing print the first sheet sails through the printer and out the back with no print and the second sheet jams - no matter what I do - changed paper - turned...
    I have problems with paper jams all of the time and it won't print once it jams. I turned off the printer, unplugged it, plugged it back in and turned the printer back on and it worked. You could try that.
    Jul 17, 2010 | HP OfficeJet J4580 All-In-One Laser...
    Epson RX500, Paper Jam - printing couldn't start
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
    Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
    The paper light is flashing
    My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
    There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
    I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
    Definitely NOT an office friendly machine!
    Aug 20, 2008 | Lexmark E250dn Laser Printer
    No paper
    Tracoi, first you need to clear pending prints. If your using WinXP, click the start button slide up to & left click on Printer and Faxes. Click on your printer & clear/end prints pending. Power off your printer & look in the printer where the paper path is. As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors. These little 'flags' usually kind of stick up in the middle of the plastic along the paper path. Look over the whole paper path and find all the little flags and make sure they're all moving freely. Sometime they get knocked out of place. You only need one to mess up the printer function.
    Luck!
    If this did not help just let me know & we'll try something else.
    Mike
    Apr 19, 2008 | Samsung SCX-4100 All-In-One Laser Printer
    Paper either just rolls through without printing or won't catch and sits there
    This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
    MDK
    Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
    Epson LX-300 Matrix Printer Logo
    118 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
