Question about Brother IntelliFAX 2800 Laser Fax
When faxing out, the paper doesn't feed through. I need to almost force it through and it makes a horrible sound.
  • 4 Answers
Sounds like a gear problem, May have shredded itself.
I know with some of the similar models i fix this happens,
So could also be the same fault with this model machine
Posted on Sep 29, 2009
WHEN FAXING, PAPER WON'T FEED
Lift up the top cover and check the rollers for wear.
Jan 31, 2014 | HP LaserJet Office Equipment & Supplies
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
Hi, my calculator casio hr 8tec shows the message " e P" and it's doesn't print anything. It`s like it's stuck.... Thanks
It thinks it's out of paper.
Pull out and re-feed the paper.
If it's out of paper, put more in.
If that doesn't help, remove the paper, and take a look at the paper out sensor, and make sure it's functioning ok, and re-insert the paper.
Jun 27, 2011 | Office Equipment & Supplies
Automatic document feeder(ADM) for Muratec F-112 fax-printer will not grab paper for processing. Wheel spins but paper does not advance unless forced into ADM
There is a small "re-feed" pad under the PF Roller which might need replacing OR the PF roller itself may need replacing. The machine when new should have come with a spare "re-feed" pad.
Nov 16, 2010 | Office Equipment & Supplies
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Whenever I send a fax on my brother intellifax 2820 it feeds crooked, I can not get it to go in straight. Therefore, the receiver only gets half the fax.
what you will need to do is go to a hardware store and purchase some isoprophyl alcahol. put some on a rag and clean the paper feed rollers if that fails there must be some in side that area like a peice of paper, try cutting a file folder to 8x11 in manually force feed thru a the paper feed section. good luck brother tech
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jam inside
check inside the machine for a little black sensor flag that may be stuck.. It should be able to swing freely. There are two or three of them in various places of the paper path.
Dec 26, 2007 | Brother IntelliFax-2820 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
54 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
