Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Hoover HNWF 3135-80 machine not controlling drying temperature
Dryer not controlling temperature causing the thermal switch to trip.
Where can I get the wiring diagram for this machine in order that I could trace the fault?
2 Suggested Answers
  • 1462 Answers
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Posted on Apr 19, 2007
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Tumble dryer doesn't dry. It tumbles but there is no heat
Either your heating element went out or your thermostat (which regulates the temp).
Jan 29, 2010 | Hoover Nextra 160 HNWF 3137 Front Load...
When I use the tumble dryer it does not cool down at the end any suggestions as to what could be causing this? Regards Caroline
Yep.....the secondary switch in the timer has welded together. Better Replace the whole thing. If money is a problem......wait for the clothes to cool down before handling them.
Oct 24, 2009 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
85 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
