Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos is slow to turn on - it looks as if it looping through all inputs to detect the live one (HDMI). Can I somehow speed things up
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • 441 Answers
SOURCE: I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Posted on Jul 24, 2009
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
My Sharp Aquos LCD TV 40E77U is working on the analog input but won't detect HDMI inputs?
This set MAY require or have available a software upgrade for this issue.
Contact Sharp to see if they have it or if this is an issue in their database that is common.
Mar 20, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When plugging in a new PS3 to hdmi input 4 or 5 on the Sharp Aquos LC-42D62U, it is not picking up the connection and I can't select it on the input menu
Does the HDMI output on the PS3 have to be turned on first in its settings? Make sure the settings on the PS3 are at a minimum of 720p as if it is set to 480i the TV probably wont notice anything connected to HDMI.
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Apr 02, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
480i to 1080i?
It depends on which input you are using, but the HDMI inputs are auto detecting. Most likely whatever device you have connected is not putting out a 1080i signal, and needs to be configured to do that. Once you do, you should see the input icons on the top right briefly come up, and below the input number, you should see "1080i"
Feb 01, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can't turn of Closed Caption
check to make sure they are not on auto
Dec 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
445 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
