Question about Dell Dimension 4600 PC Desktop
Roxio media manager trys to install on my desktop
There is no way to end it, continually comes back - what should i do?
    President:
  • 1,187 Answers
If you have the Roxio installation CD:
Insert the Roxio CD into the drive and allow it to complete.
-- or --
UN-install it and then re-install it.
[Start]
[Control Panel]
[Add or Remove programs]
Locate the Roxio Media Manager and click the [Change/Remove] button and "remove" it.
Re-boot
It is gone.
If you want to install it (yes you do) the insert the CD and install.
re-boot
Posted on Sep 28, 2009
Roxio update manager trys to load on my computer. When I try to remove it from my programs I get a message that states I cannot remove it because it is attempting to install. Any idea's?
Wait for it to finish if it is installing, or if it isn't go to control panel and select Programmes and features. Scroll down the list when it has settled and select Roxio then Uninstall.
That will stop it.
Nov 28, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Evrey time my computer starts up it automatically trys to install roxio media manager
If you want it to stop simply go to "run" type msconfig and click on startup blind. Simply untick anything that has Roxio in it, reboot and voila no more agro.
Dec 23, 2009 | Dell Dimension 4600 PC Desktop
Roxio Media Manager Keeps Trying to Install whenever I start the computer. I have a Blackberry Storm with software installed including Roxio
goto start---> Run & type "msconfig" .. in that go to "StartUP" Tab and click "Disable All " Then Apply and Restart . It will solve your issue.
Aug 24, 2009 | Dell Dimension 4600 PC Desktop
the Roxio Media Manager is belong to the system, and this part the program is in need to run part of the system...
Jun 17, 2009 | Dell Dimension 4600 PC Desktop
Roxio update manager cannot find Um.msi
I found this...may be helpful...
Usually, a "UM.MSI" error means that the update manager may have become corrupted and needs to be reinstalled
To resolve :
> Permanently remove the Sonic Update Manager. This will not affect the performance of any Sonic/Roxio software currently installed on the system.
> Reinstall the application.if any errors while installing then install the fix.
> This may be caused by removing certain non-Sonic/Roxio applications that share file resources with our Sonic/Roxio software. To fix, you will need to replace these files with this fix utility: http://tools.roxio.com/support/dell/isum_hotfix.exe
> Be sure all Sonic and Roxio applications are shut down before launching this utility. This hotfix requires a reboot. No reinstallation of the software is necessary.
Apr 19, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Roxio Media Manager continues to try to install
After reading your problem I came across some interesting references about roxio and agent.exe.
Seems agent.exe is used by many programs to update themselves over the internet, and it was giving a lot of people headaches by using 70% or more of their CPU, like yourself.
So, I wanted to send you a few quick thoughts on how to hopefully fix your situation.
First, there were complaints about stuff trying to install itself on and on, and it was because there were command lines in the STARTUP MENU calling upon them to install every time windows starts.
So to try to fix this if its happening in your case........
Go to start>run>and type in msconfig and click ok.
Now click startup and uncheck these items.
issch
ISUSPM
'ISUSPM Start Up'
'ISUSSCheduler'
Adobe Reader Speed Launcher
Quick Time Task
Igfxtray
HotKeysCmds
MSMSGS
WMPNFCSG
COMMUNICATOR
PERSISTENCE (igfxpers)
DLA
Then click apply, then ok and restart your computer.
When windows starts, you will see a window saying that changes were made to the configuration utility. When you see it, click on the little white box saying not to show this any more.
And if you really miss not having something you unchecked, you can always go back there and recheck it!
Maybe now you will have the chance to purge all things Roxio from your system.
Best of luck!!
Jan 01, 2009 | Dell Dimension 4600 PC Desktop
Removing Roxio media manager
You can try to download revouninstaller or ccleaner, to uninstall the programs.
Oct 15, 2008 | Dell Inspiron 1300 Notebook
My computer is locked up with the Roxio media manager unable to shut down or cancel out and I cant delete my blackberry install etc??
well when an application is locked and (not responding) try to force it to shut off by going into task manager (rick click on the bar at the bottom of your desktop on any unused area and a menu will show the task manager then select it by clicking on it, or to type ctrl+alt+del and select task manager) and go into applications and select the application an click on end task, and click ok on any other window that comes up thereafter.
if that does not get your application to shut down, try to do it by looking for the process that runs the application and go into the processes tab in task manager and end any process related with the application (you may need to know or guess what process to end as the names sometimes may be acronyms of short versions of the actual name of the program you're running on the system.
Oct 08, 2008 | Computers & Internet
I removed roxio creator 9LE on windows vista how do i reinstall?
You will have to either install from the original installation disc, download another copy, or install from your restore disc. Good Luck!
Jul 09, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
178 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
