How to identify the problem if the fuse is deffective?
  • Audio Player... Master
  • 5,056 Answers
Suspect an overload in the power supply or audio output stage. Look around for burnt parts, damage or anything that looks wrong.
Posted on Oct 07, 2009
What is the problem with my qsc plx3002 no power? i found the deffective parts then i replace it with a good parts then it cannot on the amps.. No beat of relay, what would it be the other deffective?
first of all pls. check the unit for any blown fuse, if there is replace it w/ the same type & value. do not replace it W a higher or lower value.
Jun 15, 2013 | Audio Players & Recorders
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
Its on stand by but wont start up
In that case or problem of you television,the cause is the deffective power supply.The power supply is dead or has a low voltage output.The cause of that problem of power supply is the deffective capacitor.The capacitor is totally leak and cannot filter the voltage.The leak capacitor can cause of volatge drop.So if you want to repair the power supply,try to pull out the power supply to the cassing and remove the cover to see the leak capacitor.You can identify the leak capacitor through visual checking,if you don't know how to use the capacitor tester.If the capacitor have rounded shape at the top and have some moise,that a leak capacitor compare to flated top shape of the good capacitor.Replace all leak capacitor with new and same value for example.330mf/35v.Avoid short circuit at the PCB board of the power supply.Try my suggestion or procedure.Hope it will help you.Thanks..
Aug 29, 2011 | Televison & Video
Small picture
Usually if the picture of the television is small the problem is the power supply.The power supply have low output voltage.Theres a deffective filter capacitor,so it is need replace.If you have no knowledge to identify the leak capacitor in using tester.You can identify the leak capacitor through visual checking.Try to look the power supply of your TV.If you can see the good capcitor,the top part is flated shape,while the leak capacitor is round shape at the top parts.Replace the leak capacitor.
Aug 18, 2011 | Televison & Video
Caught on fire
Its a major repair.Expected that the fuse is busted and others parts of pawer supply is deffective like the regulator transistor,diode,resistor and capacitor.If you try to replace all deffective parts,replace it with the same value of parts replacement.
Jul 12, 2011 | Zenith B32A24Z 32" TV
I have a sony 21"
Maybe the regulator transistor is deffective,it can be identify if deffective by using digitdl tester to check the parts if good or not,The problem of your TV is in the power supply,Need for troubleshooting.
Jul 11, 2011 | Televison & Video
I cannot get any sound from my wega KV-24FS120 sony. Sound does not come from TV speakers themselves. I tried MTS and all the audio functions. What to do? Demian
Hi,There are three cause of no sound,ethier the problem is in the speaker,sound driver or output and from the audio setting.First is check the setting, that you already done that what you sad.Now check the speaker if good or not,Use analog or digital tester to check the speaker if good or not or test the speaker to the other amplifier to identify if good or not.If the speaker is deffective replace it and if the speaker is good the problem is in the sound driver.Maybe the sound output ic is deffective or no supply.Thats why it is needed to troubleshoot and repair the sound circuit section of your television.Thanks
Jul 11, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Plug tv up and green light comes on for a few sec and then powers down
IF LED IS BLINKING then following is the situation..............
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place....... IF LED IS ALSO NOT BLINKING then following is the situation............fuse is gone due to deffective component in power section .................. so my suggestion contact near by TV service engineer or approach SANYO service centre ....this problem cannot be solved by user unless user is a technical person, having idea about components (resisitors,transistors, diodes, ...etc), having tools like multimeter ,soldering iron , soldering lead ,flux, desoldering coil, etc....
Apr 13, 2011 | Sanyo Televison & Video
HP Compaq NX6125 Laptop making a clicking noise when playing DVD
If it only happens when playing DVDs then that drive may be deffective. If it happens without playing dvds then it may be the Hard Drive. You may run a test for the Hard drive to be sure. The computer should have its own but you can also use SeaTools
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Also you can try playing the sounds of deffective hard drives from this website to identify the cause
http://www.drivesaversdatarecovery.com/company-info/recovery-tips/
Mar 25, 2011 | Computers & Internet
I have a 900 watt microwave when i turn my microwave on it blows the fuses in my cable what size fuse do i need
hi there, if you're using your power inverter to run your microwave oven isn't it? surely it is not advisable to plug this appliances for this really consume a lot of power...and eventually overload your PWR Invrter..if you use you power inverter in diff. load like lightings or a small dvd plyer and runs smoothly...is your microwave has no deffect if plug in wall socket and still blown the fuse...you have a deffective microwave oven..every time you replace the fuse w/ same type or ampereage and still blown you have a shorted power supply...try to bring your microwave oven in service center...nice day..
Feb 12, 2011 | Cobra 2500w Power Inverter
23 people viewed this question
 Grubhead
Grubhead
