Question about Magic Chef CTB1821AR Top Freezer Refrigerator
Magic chef model rb192p Water dripping into fresh food compartment. I don't see how to take freezer compartment apart to clear drain hole
docjohn174
  • 943 Answers
SOURCE: Does not get cold enough.
HI THANKS FOR YOUR QUESTION.tHE FIRST THING TO LOOK AT IS . iF YOU HAVE FROST BUILD UP ON THE WALL, OF FREEZER.#2. IS THE FAN RUNNING. #3. CLEAN ALL COILS AT THE BACK, OF FRIDGE, VERY IMPORTANT . tHANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
SOURCE: hole
you have punctured one or more of the refrigerant lines. Your chances of fixing this are slim, but if you can find the hole, you can solder it shut, then pressurize the unit with new refrigerant. The former you might be able to do yourself. The latter will require you to get a repairman who has the necessary refrigerent and valves to re-load the unit. I would guess the cost of repair is probably more than the unit is worth.
Posted on Feb 08, 2009
woodchuck789
  • 4059 Answers
SOURCE: Is there a replacement part for the freezer
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Aug 22, 2009
heatman101
  • 43501 Answers
SOURCE: Ice formation in Magic Chef Top Freezer Refrigerator
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
  • 1891 Answers
SOURCE: My brand new Magic Chef
it is not normal . the old saying ( frost clear .) it say's something right .. so you have a defrost problem with this unit look for heater system / defrost terminator / and the timer or what most use is adative defrost control / a pc board . that knowes what is going on .. mm hope this helps ..
Posted on Aug 17, 2010
Water dripping in fridge from below frezer
There is a drain tube that runs from the freezer/ evaporator compartment that allows ice melt water to drain from the defrosting cycle. Often times that drain hole will become clogged with food debris, glass from a broken heating element, paint chips from scaling and mildew, etc. When that drain hole gets clogged the water has no place to go except down into the fresh food compartment. Unplug the ref and remove the food and ice maker and racks. Remove the freezer back panel and look for a drain hole and clean it out. I use a wet/ dry vacuum at first and if the clog is deeper I will use compressed air to blow the line clear. You can also use a water hose with water pressure. Best done outside of the house.
Feb 09, 2014 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Model ET18NKXDW06. Water dripping from freezer down back of refrigarator. Placed bowl underneath opening to catch water. Should be going down to catch pan right???? Help Nell
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Model rb17ka-1al food section not cooling but freezer works fine
That is gonna be a bad fan motor up top OR the drain pluggs up and puddles water between the two sections. The freezer works fine but no cold air can get to the fresh section below. Seen it. Thaw here out and yank out the floorboard of the freezer. Clear the drain and oil the fan motor. No parts needed.
Aug 07, 2011 | Magic Chef Refrigerators
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
Water dripping from freezer into refrigerator
Hi,Most likely the drain in the freezer is clogged up and frozen. Every time when your fridge automatically defrosting defrosted water dripping inside the fresh food compartment. You have to remove the back panel in the freezer and using a hair dryer defrost the drain which is located under the evaporator coil. Then put very hot water through the drain until it goes free.
Yes, you need to remove the back panel inside the freezer, It should have screws that come out then it should pull off and out.
On your model, the defrost drain hole/line is located inside of the freezer behind that back access panel, just remove that back panel, remove your freezer floor panel FIRST(Has 2 screws in front), that simply pulls out, then you will see the drain hole under the evaporator coil. It may be iced up, you will have to clear all of the ice and run hot water down the drain hole.
Once the back panel screws are removed that panel should just pull off, pull hard. Make sure your refrigerator is unplugged first.
Good luck.
May 28, 2011 | Kenmore Top Freezer Refrigerator
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Magic Chef CTB1821AR Top Freezer Refrigerator Logo
102 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
