Question about HP Officejet Pro L7680 All-In-One Printer
I have had my L7680 for about 3 years, worked great, the printer isn't printing. I purchase a new black cartridge 3 months ago, has been working. I have rebooted the printer a couple of times... nothing
  • 9 Answers
SOURCE: HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Posted on Oct 29, 2007
  • 238 Answers
SOURCE: computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Posted on Dec 17, 2007
insomniac
  • 103 Answers
SOURCE: HP L7680 stopped printing
if you still have the software completely uninstall the software and drivers and reinstall. go to the hp website and see if there is any updated or fixes for your specific printer. let me know how it works out for you.
Posted on Feb 26, 2008
SOURCE: new black print cartridge not working
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Posted on Jun 17, 2008
JayBlair
  • 328 Answers
SOURCE: HP L7680 black print streeks every 5-6 lines
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
Posted on Jul 30, 2009
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
This printer has not been used much since it was purchased 4 years ago. The black ink will print/copy, but misses about 2 lines in an alternating pattern. I'm new to this machine. Have cleaned heads,...
Ink cartridges don't do well when you let them stand for long periods. The ink dryes up on the print head. Try taking out the cartrige then take a damp paper towel with hot water (microwave works great for heating it up) draw the print head over it several times until you see ink flow evenly. them take a dry paper towel and draw the in head over it the same amount of times and reinstall. If doesn't solve the problem you may need to replave the cartridge.
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
About 2 years ago, I purchased a Samsung laser printer, model number ML-2510. It performed very well until about a month ago, when I put in a new cartridge, number ML-201003/SEE which was different from...
/SEE is the cartridge for the European version of the printer, /XAA is the version for the U.S. I can't imagine why it doesn't work, but there's a reason for the European designation..
Jul 20, 2009 | Office Equipment & Supplies
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
Mar 23, 2009 | HP DesignJet 100 InkJet Printer
Hp deskjet 656c series
hey in printer preference in advanced untick the print in grey scale
Jan 12, 2009 | HP DeskJet 656 Thermal Printer
Kodak 5100 no black printing, light on colors
Had the same issue... No black ink. Called the # from "Solution #1" guest, 18004216699. Had to patiently go through all the basic trouble shooting stuff like calibration, print head clean, demo print, etc. Once I went through that, they issued me a new print head for free, no shipping charges or anything. Just did this today, but they say I should have the print head in 3 days.
For once, service worked like it should!
Jun 18, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
HP Officejet Pro L7680 All-In-One Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
