Question about Panasonic PT-61HX40 61" Rear Projection Television
I have a panasonic PT61HX40B and it keeps going black. It still has sound but no picture. The bottom of the tubes/projectors are orange so they are powered but nothing coming out of the top of projectors. If i let it run for a bit it will come back on but then does the same thing again. I checked for burned or damaged circuit. But only found that the TNPA1412 board is the only thing that looks like it might have got hot its discolored.I cleaned it all out inside and checked every connection and they all seem good. What is it?
    Sergeant:
    Champion:
  • 231 Answers
Sounds like a lamp or pc board
Posted on Apr 13, 2010
Black and white picture no color
This is going to be one of two things on this. Either your cable going into this is bad or one of your display boards went bad. Replace the cable you have going into the projector first. They go bad all the time.
Jan 29, 2015 | Panasonic PT L735U Multimedia Projector
Optoma hd72
It sounds like you bulb is ready to die. First clue is picture quality. That happen to me and a new bulb remedy the problem. Bulbs are expensive though.
Jan 28, 2014 | Optoma HD72 Multimedia Projector
My 65" sony rear projector
shorted green tube sony had major problem with Tubes
May 27, 2010 | Sony KP-65WV600 65" Rear Projection...
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
I have a samsung that the screen was pink now, black with sound??
What you describe is a classic symptom of burned out fluorescent tubes in the display. I'm assuming this tv is a LCD model...Unseen by the user, there are long, thin, extremely bright, fluorescent tubes along the edges(usually top and bottom) which light up a backscreen so you have a vivid image to look at. (sort of like how a doctor views xray pictures) As the tubes age, they change color and eventually burn out. An excellent example of the same technology is a laptop display or desktop lcd display--same exact design. Hopefully your unit is under warranty because this is an involved repair *if* it can be done. Most often, the whole lcd display unit must be replaced. Definitely shop around for repair facilities if non-warranty is a factor.
Sep 09, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Picture has a green outline
your convergence ic's and possible low ohmage reisistors are at fault.there the large ic's that start with stk
Sep 10, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-61HX40 61" Rear Projection Television Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
