Question about Troy Bilt Tb70ss Gas Trimmer
Purchased a new Troy-Bilt TBS75SS w/o operating instructions. How do I restring the head w/o taking it off the unit?
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
#1 Taper
  • 1040 Answers
SOURCE: can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Posted on Jun 10, 2009
  • 1114 Answers
SOURCE: line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Posted on Jun 21, 2009
SOURCE: I need to replace the head on a troy bilt TB575 ES
at the end of the trimmer where the cutting head assembly connects to the gear box there are some screws. unscrew and replace with the universal head.
Posted on May 01, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
We bought a Troy Bilt Chipper/Shredder at a yard sale and they didnt have the manual. The Model # 47279 and Serial # 472790416512--Can you tell me where I can get a manual for it.
Hi and welcome to FixYa. I am Kelly.
For parts go to this link: http://www.partsandservice.com/html/TroyBilt/cs/cs47279-4727901.html
For the Opertors manual call Troy-Bilt at 1-800-833-6990
For Parts 1-800-648-6776
This is the manual for the unit just below the 47279 i.e for the 47276 and will be close but NOT exact for your model.
http://www.brentchalmers.com/Literature/472655-447267and47276_OwnersManual.pdf
Letters:
Troy-Bilt Mfg Company
c/o Technical Service Dept
102nd St. and 9th Ave
Troy, NY 12180
Just note that this is historical information. Troy-Bilt was purchased by MTD in 2003.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Troy-Bilt Chipper Shredder
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I open the spool to restring a Troy Bult line trimmer
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
May 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Brand new , won't start, no spark at plug, switch ok
If you know for sure that it's not getting fire, then I would take it back to where you purchased it. It sounds as if it has a bad ignition module.
Jim
Jun 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
152 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
