Question about Frigidaire ATF6000ES Front Load Washer
Hello I have a problem with the front loader frigidaire washer the the door does not want to close causing the washmachine not to start.. what can I do?
    Genius:
  • Frigidaire Master
  • 1,467 Answers
Sounds like broken ******/ door handle kit... you can buy this quite cheaply...
Posted on Sep 28, 2009
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washing machine door hinge snapped
Hello - Contact the manufacturer to see if they have any updated or alternate door hinges that you can install yourself. The weight of some front loader doors, and how they are closed/slammed, can wear over time.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
How do I runa diagnostic on a Frigidaire Model 41744152400
most front loader washers will wash fine all the time, however there is a pin switch on the front that the door strikes when closed make sure the door is closed and locked .
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loader will not turn on
Hello - Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Sep 24, 2012 | Frigidaire ATF6000ES Front Load Washer
Front end loader washer door does not line up to close
Check to see if the door is sagging. If so, contact Frigidaire you might be able to adjust the door and save money rather than replace the switch.
Aug 02, 2012 | Frigidaire Affinity ATF7000E Front Load...
Front loader model#LTF6000E
IS it giving you an error number such E20???
Aug 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader not starting
First check if u can close the door with no or less clothes and see if the lock is engaged.. else if u find the door not locking see if there is any garments or threads blocking it.
Thankyou
Jun 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
171 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
