Question about SMC Barricade 7008 Router
How can I limit the bandwith on an individual
How can I limit the bandwith (usage) on an individual router port? (without unplugging)
  • 4,338 Answers
You cannot limit the bandwith, but you can give limited access to a particular user/computer. You would need the router manual to figure it out.
Posted on Sep 28, 2009
I'm trying to get online for my ps3 and i can't get a wireless connection. so i decided to just do a wired connection from the computers internet connection.how can i do that without messing with the...
1st you need a 4 port router or a modem/router combo 1 that has more than 1 port.
2nd you need to have enough CAT5 cable to get it to 1 of the empty ports on the router.
So basically the way you would hook it up if you are going to use 2 individual components is:
1. Unplug the CAT5 and power supply from your modem the one that goes to your puter.
2. Put the new router under or the side or underneath the modem.
3. The Ethernet cable that comes out of the modem plugs into the corresponding port on the router that doesn't have a number.
4. Now depending on how many ports you have I always put my puter in port 1 and then anything else goes in the other ports, you don't have to do it numerically.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
How many computers can the router handle?
The 2701hg-b Wireless Access Point (WAP) has 4 ethernet connections, that's the physical limit, for that, unless you "cascade" a bridge or another router off of a port.
It also supports wireless. I know of no documented limit as to the number of concurrent wireless connections... there probably is one, but it isn't "published", that I know of.
The "real" limits on the wireless side are "activity" and "channel" conflicts.
The "activity" conflict factor has to do with how much somebody/anybody is using "doing" with your WAP. Sooner or later, you'll see "saturation" of the wireless bandwith.
The "channel" conflict factor usually occurs when there are two (or more) WAPs (or other wireless devices) within "range", that are using the same "wireless channel".
From the "user" perspective, the effects of "conflict" are similar to "saturation", except that you'll likely see more "dropped connections" with "conflict".
Nov 10, 2010 | 2wire (2701HG-B) Wireless Router
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Rt164 reset button does not work to default
Hi friend
I hope it will work for you,please follow the steps:
1) Give the router power,then with a pen press the reset button for 10 secs,after that unplug the power cable from the router for 10 secs and wait
2) After 10 secs plug the power cable back,and press the reset button for another 10 secs,after that unplug the power cable again for 10 secs. and wait.
3) After 10secs plug the power cable back and press the reset button for 10 secs, after that unplug the power cable again for 10 secs and wait.
It will bring the router back to default settings.
now if your ethernet ports have limited connectivity,please follow the steps:
If you have windows XP try this
1) connect the computer with a wire to the router
2) click start menu>contrlo panel>to your left you will see switch to classic view,click that
3) Double click and open the icon named network connection
4) right click the icon named local area network connection,click properties
5) Now click the tab named "configure" under the general tab
6) Click the tab named "Advanced"
7) Under that tab you will see something named "Property"
8) Inside that white box you will see either "Speed/Duplex" or "Link Speed/Duplex", select that
9) To your right just beside property you will see 10 mbps half duplex,select that and click OK
10)Click Ok if you find any or click Close,whicever is there.
Restart the computer and enjoy working without any limited connectivity.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Computers & Internet
Cannot add a new laptop on my eHome wireless router
There is not a limit to the amount of devices that can hook "wirelessly" to your router, but your bandwith is limited. Internet bases phone services will eat up a large majority of your available bandwith. try limiting the bandwith of your phone service or disconnect it all together and see if you can then connect.
pls rate as "very helpful" if this assists you in your problem. ^_^
Sep 21, 2009 | Computers & Internet
Tools for watching intenet usage on a network?
simply turn of one computer and mesure the bandwith and the next one and............
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
Tmobile voip
the thing with voip is it eats up bandwith, especially if alot of users are using voip at the same time, that tends to slow their server they result in blocking the ports for that.
Oct 16, 2008 | Linksys Wireless-G Broadband Router
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
Video chat room
Well, any type of streaming video will need a good amount of bandwith to transfer without interuption. If you were, for instance, plugged directly into a cable or DSL modem and it worked fine, and now youve set up a wireless router and moved your computer across the house... it's possibl;e your computer is not getting a good connection. If multiple computers share the same connection through this router then they are all sharing the limited bandwith you get from your ISP. Try (if possible) moving the router (and or cable/dsl modem) closer to your PC and make sure other aren't online when you are.
Feb 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
SMC Barricade 7008 Router Logo
99 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
