Question about HP PSC 1315 All-In-One InkJet Printer
Attempting to print - printer spits out two blank sheets, then prints page, then sends another sheet half way through and jams with error lamp on
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: paper jam light is on
Guys .. the same problem again ... I solved it putting almost the full capacity of sheets into the paper feed, and when the print begins, push a little bit de hole package of sheets inside .... the printing should work just fine ... but ... it doesnt work for long docs, because, when the pile of sheets starts to became smaller, the problem cames back again .....
and for the record .. it is my last hp ... too.
Posted on Nov 04, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
PeteG0429
  • 34 Answers
SOURCE: Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Posted on Apr 02, 2009
PeteG0429
  • 34 Answers
SOURCE: My printer HP Photosmart C7200
Here's a solution. Easy fix. Hope it helps!
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
HP Deskjet 970 Some Duplex Pages Printed with One Side Blank
You have to check the settings when sending a print job through
Mar 21, 2017 | HP DeskJet Office Equipment & Supplies
Try to print mapquest directions and sends blank sheet out
Internet printing can be tricky because everything is in HTML which is not designed for printing but for clicking. So there are links and features but when you try to print it can be blank or half pages. Is there a button on the site that says printable view or print these directions or something similar? If you click on that it should allow you to print the page as you see it on your screen.
Jan 28, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
