Question about Traxxas Rc Revo Nitro Monster Truck
Revo 3.3 top end cuts out after driving for 1 hr in dusty place.. I replaced glow plug, cleaned filter and returned carb back to factory settings. Still have the problem. I also took needle and seat out to see if something was stuck in there, didn't see anything. Also checked fuel lines and replaced gas. Called traxxis and had no real help.
  • 88 Answers
Are you checking your engine temps? These engines do not like to run at more than 240 degrees.
Posted on Dec 10, 2009
What will make a teryx spit and back fire but u cant drive faster than 5 mph
Do all these:
#1 clean or replace air filter
#2 replace spark plug
#3 have carb professionally cleaned and set. (after the shop cleans and sets the carb they should test drive it.. if it doesn't run properly.. you have already done work they will (would charge $$$ you for).. and it will take some serious professional investigation. Get a K&N filter.
Apr 30, 2014 | kawasaki 2011 Teryx 750 FI 4x4
Fs 220 has no power
1. Separate the shaft from the engine unit, and see if it revs out without being under load. If this solves the problem it could point to a clutch/driveshaft/gear head issue.
2. Try re-tuning the carb. unscrew both H and L carb screws 3 or 4 turns, pull over until it fires, it may even run high. Then screw both H and L screws all the way in (clockwise). Turn the H screw out 3/4 of a turn and the L 1 full turn. This should set it back to factory settings, if this hasn't solved the problem then you may be looking at stripping the carb down and replacing diaphragms and cleaning out.
Feb 10, 2013 | Stihl Garden
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Fuel line replacement poulan 2250
cut one end of the new hose down to 1/3 about a 1/2'' long slide a wire threw the tank and out of the gas cap opening slide the new hose trimmed end and pull the wire and hose back til the trimmed end sticks out pull the hole threw connect the filter to the end and pull into place trim and connect to the carb the return side do the same way just without the filter
Aug 21, 2012 | Poulan Garden
Take apart stihl blower for repair
If you have the correct Stihl hose , then pull air box off and will probably have to remove the 8mm nuts that hold carb on and disconnect the fuel line and fuel return line and throttle linkage. then empty the fuel tank and pull the filter off the end of the hose and remove from the top. You will have to probably make yourself a hook out of rigid wire, hanger works good, just something to hook fuel line to pull through the cap opening so you can pull filter off old hose. then insert new Stihl hose from the top and grab it from the fuel cap hose with needle nose pliers or hemostats and pull gently not cutting the hose but enough to pull hose into tank to where groment on fuel line is in place in tank, then install NEW fuel filter and make sure your return line is good, I would replace both while I'm there, then reassemble it. if it doesn;t run right you may have to pull carb back off and dissemble it and clean it cause it may have sucked dirt through the crack
Nov 17, 2011 | Garden
2007 CRF 450 R- from 1/2 TO full throttle it backfires and cut out,as soon as you release the throttle it comes back to normal.Below 1/2 throttle all is fine.Cleaned the carb ,checked all jets and fuel...
This can only be lack of fuel for some reason backfire is nearly always lean fuel condition and the cut out pretty much confirms lean or no fuel?
I would be checking the size of main jet (they numbered) double check it is factory size? I would check the needle clip position god knows why but people change the position so double check it is factory setting (usually 3 or 4 notches from top is factory setting I forget which one it is for Honda's) I would double check your air filter is clean and/or not oil drenched
refer to your manual or ring your Honda dealer for all the specs
Some other possibilities would be spark plug fail at high load (but unlikely?) stator failing at high RPM ( unlikely but worth the two minute multi meter test to make sure resistances is still in spec)
good luck regards Jamie
Jun 01, 2011 | 2005 Honda CRF 450 R
Carb Problems
Once high end needle is screwed fully in you can u twist screw 3 full complete turns and then wind more in as youre tuning.
Jul 19, 2010 | Traxxas T Maxx 3.3 Monster Truck
Where is the oil pump located on a 1999 ford taurus and whats items do i need replace a long with the oil pump
Remove oil pan oil pump and pick up tube & screen will be bolted on.
You should get oil pump lube, carb. cleaner, new pump oil,
oil pan gasket, silicon, oil & filter, loc-tight, gasket remover & tools metric, 1/4 drive socket set, scraper / putty knife, 2 jack stands, a jack or ramps,
& blocks for rear wheels.
Lets get started.
(1)Get your car up on stands or ramps block rear tires.
(2)Drain oil & remove oil filter remove battery cable NEG (-)
(3)remove pan
(4)remove old pump
(5)remove pick up tube from oil pump
(6)Now clean tube & screen with carb. cleaner place on news paper to dry.
(7) clean all old gasket off from engine & pan also clean bolts
(8)place silicon on pan place gasket on pan put bolts in from gasket side to Aline holes put a side to dry
(9) Attach tube to pump with a little loc-tight fill pump with oil pump lube
(10)attach pump to engine block make sure rod goes in proper & bolt are tight.
(11)Bolt pan back on engine using a 1/4 in drive ratchet don't over tighten bolts get all bolts in now slow run each bolt in starting at 1 end then jump to the other then go to bolt at other end a cross from 1st bolt. Do this till all bolts are ran in. Now tighten bolts look for gasket on side of pan.If it starts to push out stop go to next bolt.
(12)Instill new filter & drain plug,& pour in oil
(13)Replace Neg - cable
I hope this works for you it's a basic oil pump change for most cars.
Some take more steps.
Jul 14, 2010 | 1999 Ford Taurus
How do I replace gas tank lines?
The inlet line will be an .080 x .140. Using side cuts, cut line at a slight angle and feed into tank. Pull through gas cap opening, cut line straight, and install filter. Pull line back into tank so filter lays on bottom. Connect to small carb fitting on side of carb.
The return line is 3/32 x 3/16. Connect one end to pump return next to primer, cut other end at angle and install about 1/2" into tank.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
I have a revo 3.3 nitro and im having problems starting it im am indoors about 70 and im flooding the engine i go through the steps for a flooded engine but the easy start won't turn i let it cool...
i'm new to revos two but i just bought a couple and had the same problem with one of them, make sure your glow plug is ok or just replace it and adjust your high speed needle, i'm in oregon i had to richen mine about 1/4 turn. i also noticed both of the models i got were set differently from the factory. there's info on traxxas website on where the factory needle settings should be.
Feb 02, 2010 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
124 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
