Question about Kitchen Ranges
I have akenmore gas range. i replaced the spark
I have a kenmore gas range. i replaced the bake ignitor now the oven comes on but will not shut off
  • 42 Answers
The ignition gap is to far from the burner it is not sensing the flame.
Posted on Sep 28, 2009
1. Sears Kenmore Gas Range 2. Model No: 362.75481890 The oven will not ignite. The igniter-oven burner will glow but the gas will never start to flow. This has gradually occurred and has now come to...
Hello Everett,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when set to bake ignitor by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than that replace bake ignitor. If you dont have amp meter take my word for it since in my 30 years appliance repair career i have when the ignitor comes on, that it's weak, to be the problem 100% of the time
Jul 31, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool range lights sometimes but not everythime. also, it ignites and then quits before we are done baking something. how do i repair this? Thanks, Curtis curtis.jcm@gmail.com
Your oven ignitor is either out of adjustment or going bad.
Turn off the gas.
Open the oven and remove the lower oven cavity pan to access the ignitor.
Set the oven to BAKE and watch the ignitor.
If the spark is irregular,turn the oven control off and adjust the spark electrode closer to the frame.
Turn the oven back on and observe the spark.
Repeat this until you get the best consistent spark.
If it stays irregular,replace the spark ignitor.
Copy and paste the link below for a visual of the ignitor.
http://www.appliancepartspros.com/part_details.aspx?part_id=2990525
Sep 21, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Hello. My Kenmore plus gas range oven does not work on bake. It does work on broil. I removed the lower heat deflector, the heat coil comes on but there is no gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 04, 2010 | Kenmore 72002 / 72004 Kitchen Range
KGST307 Gas Kitchen Range: gas range will not heat up when using Bake setting...
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
May 16, 2010 | KitchenAid KGST307 Gas Kitchen Range
My gas stove is not working(the oven only)
May 12, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven
Mar 28, 2010 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
GE Profile Gas Range, oven doesn't heat up on any
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list above.
Jan 28, 2010 | GE Profile JGS968 Gas Kitchen Range
My oven does not light , only the propane comes through , and i have to shut it down , does not get up to temp
Your glowbar ignitor part number 5303935066 must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
The part is approximately $65 thru the Sears parts site.
Dec 28, 2009 | Kenmore Kitchen Ranges
I have an Amana acf3325a gas range. the oven will
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace. Part number is 74008064.
Keep in mind, ignitors are fragile.
Dec 28, 2009 | Amana ACF3325 Gas Kitchen Range
Kenmore Oven
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
