Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Hard drive makes a clicking sound and does not connect to my Macbook Pro. When i unplug the USB or firewire cord from the computer and turn on the drive, it doesn't make the clicking sound
  • 138 Answers
If the harddisk is making clicking sound,, then there may be an failure of motor inside it,,, ,, nothing but giving your HD for replacement by manufacturer
Posted on Sep 29, 2009
Drive not working/ not showing on desktop/ green light showing on powerpack but light blinking amber / yellow on the hard drive
Do you hear a clicking sound while the HD (hard drive) is ON? If not, here's what you need to do:
1. Try to connect the HD into different USB ports of your computer. Or might as well, try different computer.
2. If you're using USB cable to connect the HD to the computer, try different cable. If it has a FireWire connection, then try FireWire.
3. If same problem occur, check the Disk Management of your computer while the HD is connected. To check the Disk Management, here's how:
- Right click "My Computer" (for XP) or right-click the "Computer" icon (for Vista or Win 7).
- Go to"Manage", then select "Disk Management".
- List down all the drive letters that you will see. Include the "Unallocated" disk space on the list(if there is), then unplug the HD from the computer.
* If there's a drive letter that disappears, then it's your HD. You may reconnect the HD to the computer > right-click on the HD's drive letter > change drive letter. Try to set the drive letter of the HD in drive X: or V:.
* If the drive letters remained the same, though you disconnect your HD, then, it means that the HD is no longer detected by the computer.
* If the HD appears to be "unallocated", then you need to reformat it.
*** However, if you're hearing a clicking sound, I'm sorry to inform you that the HD is no longer working. That clicking sound is also called the "click of death".
Thank you and good luck!
Jul 04, 2010 | LaCie 500GB FireWire-400 Porsche - 7.2K...
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original...
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Feb 07, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
Firewire 800 cable
No such thing s a dumb question, I transfer from my Canon XL1 to my Mac IBook with firewire all the time. You have three choices: 1. Buy a cable with two different ends - one that will fit your camera (the tiny one so small it is hard to insert) and one that will fit the Mac. Your Mac should have two different types of firewire ports - the semi-round one and the square one that looks like a USB port, but isn't. The symbols are different  for firewire ports firewire and USB ports. But all firewire ports, regardless of the configuration will have the firewire symbol and all USB ports will have the USB symbol.  Either firewire symbol port will work. I have two different firewire ports on my MacBook G4 and use them both,  I keep a bunch of firewire connectors around. They usually come with outboard hard-drives in various configurations. Sold en Ebay or at computer stores Solution 2: Feed your firewire through an outboard drive that will accept the 400 firewire (many do) and then take another firewire, say an 800, from that drive into your computer. I always capture to a hard drive then edit from there. The idea of a firewire bus is that you can connect a number of drives in parallel and mount them all. Available for as little as $69.
Solution 3: Buy a firewire port card for you MacBook which slips into a slot on the side, and gives you connectivity with the 400. It also frees up your main firewire port. I bought one on Ebay for $24 that came with all the adaptors. I was pulling my hair out too until I figured out the system.
Nov 28, 2008 | Sony DSR-11 DV / Mini DV VCR
I have aSmartDisk Firelite FWFL80-N, the firewire ports are producing a weak connection connection
Problem may not be the case. If you holding the cord the port that the cord hooks into is going bad. Do the cheap repairs first, check the connection or replace the cable first then the case.
rmatheson@wowway.com
Sep 30, 2008 | SmartDisk FireLite 80GB 400Mbps FireWire...
Don't remember how to use
I also have a Monsoon 320GB hard drive.  There is a power cord that attaches to the hard drive and the power source, make sure that the drive is turned off, plug the power cord in to the drive and the power source.  Mine came with two types of connectors to connect the hard drive to the computer.  Firewire to Firewire and a usb cord.  Use one of the cords to connect the hard drive to the computer.  Then turn your drive on.  If an icon doesn't show up on your desktop you can restart your computer, that usually works for me.  The drive functions just like your internal hard drive.  If you want to save files on the external drive just choose that option when saving a file.  Hope this helps.
Jul 30, 2008 | EZQuest Monsoon Hard Drive
Issue connecting HD Video Camcorder HV10 to MacBook
The USB cable is only for downloading still pictures from the camcorder. I don't know of any way to download movie unless you have a computer with the necessary IEE1394 (DV) terminal. Sucks as I have a Macbook Pro and can't download the video!
Jul 14, 2008 | Canon HV10 HD Camcorder
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Not recognized on Mac
In my experience those enclosures are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Oct 20, 2007 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
1,289 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
