Question about OKI MICROLINE 280 Elite Matrix Printer
Oki 280 will not feed paper - OKI MICROLINE 280 Elite Matrix Printer
flopez
  • 161 Answers
SOURCE: OKI PRINTER B4250
You have accidentally pulled the back paper tray. Even when pulled a little, this tray tells the printer to deliver output to the back. This is useful when printing on heavy, or thick paper. Just push it back all the way down to it's original place.
Posted on Sep 26, 2007
  • 8 Answers
SOURCE: oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Posted on Sep 26, 2008
  • 8 Answers
SOURCE: oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
  • 40 Answers
SOURCE: Oki ML395 printer, paper continues to feed
your paper feed sensor maybe stuck or a piece of paper could be stuck in the sensor.Hope this helps ?
Dezzi
Posted on Nov 29, 2008
  • 97 Answers
SOURCE: OKI 5100n Will not feed paper
Take out all consumables -
toner, drums, image belt
check for scraps of paper
take out paper tray
check for paper inside
open all doors in front and reat
check for paper scraps
Posted on Mar 29, 2010
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
take out paper tray
Mar 26, 2010 | OKI C5100n Laser Printer
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Constant jamming recently
Could be 2 things..
First Check close and make sure there are not small bits of paper in the feeding arms rollers etc.. any place paper passes make 100% sure. Second adjust the tension from the feeding arm and make sure the paper path to the printer is clear.
You can also hit it with a few shots of Dustoff
Jun 17, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Dezzi
Nov 19, 2008 | OKI MICROLINE 395 Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix... Problem
Be sure when you install new paper that the paper out switch, usually in the paperpath somewhere, is being contacted by the new paper. Usually located on the left side of the paper platten.
Jun 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Form feed length for 280
change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Feb 28, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI PRINTER B4250
Sep 03, 2007 | OKI B4250 Led Printer
OKI MICROLINE 280 Elite Matrix Printer Logo
53 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
