Question about Hydrofarm Agrosun Dayspot 60w Grow Light Kit
It is the 150 watt grow light kit I'm having problems with. I had two set up last winter season for 2 hibsciscus plants in a north facing room. They worked well until the light bulbs burned out. When I replaced the light 150w bulbs with the same from your company they only lasted a couple weeks and burned out. I tried it again and same results. I bought new grow light kits thinking the lamp mechanism was defective, same results. This is getting very expensive! What gives - it worked well last winter, and never worked well since that time. I've bought from different vendors in Madison, WI- it doesn't matter. I do have the lights on timers of course. I have not changed the outlets or the cords. Since this is in my living room, I really don't want a more utilitarian looking grow lamp, and there is no other location in this small house to put large tropical plants. Any suggestions, I have one more new kit not opened , that I'm about to return.......thanks and desperate winter is coming! Judy
4 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: light wont start up
You will have to Replace the Balast.
Posted on Jan 18, 2009
fknstart
  • 404 Answers
SOURCE: ballaster makes a ticking noise,wont fire up
make sure the light is a hps one
Posted on May 29, 2009
protek480
  • 1723 Answers
SOURCE: Grow lights don't come on
Check out the power to the timer
Posted on Jul 07, 2009
I have my tomato plants planted in pots on my patio and the plants don't look like they are growing and the leaves are small and the edges are curling up and are dark in color. What can I do?
you need to give them more room,grow bag is needed when you water use warm water or rain waterrain is best if not warm water grow bag will help if the plant is say 2 inch in a 4ins pot it will take time to grow put 4 or 5 in a big grow bag it will need light and heat don't put in pots
Jun 16, 2017 | Garden
When is the best time to prune rose plant
I like to prune mine after every blooming, but I live in a climate where it blooms year round. I am not sure where you live, but if you have a cold winter, prune them heavily just before the spring growth season. Depending on where you live that could be anytime between January and April. If these are older established roses. Prune them back after each blooming during the growing season. You will get a lot of flowering this way.
Oct 07, 2016 | Garden
How to care for ho useplant begonia rex?
Growing Requirements for Rex Begonia Plants Rex Begonias grow best in bright, indirect sunlight coming from an east or west window.
Fluorescent grow lights are also an excellent alternative to natural light for these plants,
and in many cases will intensify the foliage colors.
When potting, set the plant with the crown slightly above the soil line.
They should be planted in a porous, slightly acidic planting mix that contains some peat moss
and leaf mold. African Violet potting mixes work well for Rex Begonias.
Allow the top 1inch of soil to dry before watering, then water thoroughly.
Over watering can lead to root or crown rot! Wet foliage can cause problems with mildew.
Always use room temperature water when watering house plants.
House plants should never be allowed to stand in water for more than a few hours.
Painted-Leaf Begonia plants thrive with daytime temperatures of 70-75
and 60-65 at night. NEVER lower than 60!
They require a humidity level of at least 50 percent and appreciate periodic, light misting.
Provide additional humidity by setting the plants on shallow trays filled with moistened pebbles,
or a humidifier, especially during the winter months.
Feed actively growing plants in early spring and again in early summer with a slow-release plant food,
or every 2 weeks using a quarter strength dilution of a soluble, complete fertilizer (23-19-14).
Decrease feeding in early fall and stop altogether in the winter. Do not over-fertilize!
Your Begonia Rex may go dormant in the winter and possibly drop its leaves.
If this happens, continue to water sparingly until spring when new leaves will re-appear.
If your Rex is growing where it only gets light from one side ( a window sill),
turn the pot a quarter turn each week to maintain even growth.
Foliage color may fade under low light conditions. Consider using a grow light.
Remove any dead leaves and other debris around plant regularly.
Rex Begonias enjoy spending the summer in a shaded part of the garden.
Always be sure to check for insects and pests before bringing your plants back indoors!
Rex Begonias are susceptible to attacks from mealy bugs.
Aug 03, 2014 | Cycling
Can I grow vegetables in a greenhouse in the winter?
You can, but they can be a little challenging because they need specific temerpatures and more sunlight than there is naturally in the winter.
Jan 26, 2014 | Garden
What is the best grow lights to grow *********
That depends on what you're trying to grow and what phase the plant is in. Certain plants are adapted to grow in the shade or in warm, sunny environments. Depending on the plant, one type of light may work better than another. For example, if your plant needs a shadier environment, then a regular incandescent bulb may work best.
The other factor that goes into choosing the right grow light is what phase your plant is at. For example, a high-pressure sodium bulb may be best when your plant is in the flowering or fruiting stage.
Personally, I love using LED grow lights. Modern LED bulbs are more energy-efficient (they produce more light with less power), so they cost less in the long run. They also produce less heat, which means you don't have to worry about a ventilation system. Plus, they emit light wavelengths that correspond to the peak absorption peaks for most plants.
When choosing your bulb, you should look at the requirements of the plant and how those requirements change as the plant continues to grow. Keep in mind that the larger your plant gets, the more light it will need, so plan ahead.
Feb 07, 2012 | Jump Start 4' Fluorescent Plant Grow Light...
How and when do I cut my rose bush for the winter?
Why Prune Roses Encourage new growth and bloom Remove dead wood Improve air circulation Shape the plant Tools You'll Need By-pass Pruners Long-handled Loppers Thick Gloves (preferably long ones) Rose Pruning Basics Use clean, sharp tools Look at the overall plant, but begin pruning from the base of the plant. Prune to open the center of the plant to light and air circulation Make your cuts at a 45-degree angle, about 1/4 inch above a bud that is facing toward the outside of the plant. Make sure it is a clean cut (not ragged) Remove all broken, dead, dying or diseased wood (Any branches that look dry, shriveled or black. Cut until the inside of the cane is white.) Remove any weak or twiggy branches thinner than a pencil If cane borers are a problem in your area, seal the cut with a white glue, such as Elmer?s. Remove ****** growth below the graft. Remove any remaining foliage When to Prune Roses Timing is determined by the class of the rose plant and the zone in which it is growing. Most rose pruning is done in the spring, with the blooming of the forsythia as a signal to get moving. If you don't have forsythia, watch for when the leaf buds begin to swell on your rose plants, meaning the bumps on the canes get larger and reddish in color. Hybrid tea roses are the most particular about pruning. If you don't know what type of rose you have, watch the plant for a season. If it blooms on the new growth it sends out that growing season, prune while dormant or just about to break dormancy, as stated above. If it blooms early, on last year's canes, don't prune until after flowering.
Jun 09, 2011 | Garden
My cherry tomatoes are up.. do I need to thin them to one plant per pod?
If they are the indeterminant sort, one plant is just the thing. If they are determinant, then you may have room for additional plants ,as they will not keep adding to their mass. Happy gardening:)
Farmerbear at FixYa.com
Sep 26, 2010 | Aerogrow AeroGarden Classic 7Pod with Herb...
Why did't my garden do well?
You can do either, if you purchase a new seed kit you know the varities have been tested and grow in an AeroGarden. If you plant yourself, but sure to look for small or dwarf varities and lean toward water loving plants.
What problems did you have with your other herbs, not basil?
Sep 29, 2009 | Aerogrow AeroGarden
Growing lights Types
There are three major types of lighting systems available right now: incandescent, fluorescent, and high intensity discharge. Incandescent lights are horribly inefficient (especially the screw-in "grow bulb" type) and really not an acceptable option for plant growth. Although they are inexpensive to purchase, their cost of operation makes them the costliest source of light.
Aug 27, 2008 | Jump Start 4' Fluorescent Plant Grow Light...
Fluorescent or hid Comaparison
Until the early 1980's most indoor growers used fluorescent lights to illuminate their garden. These tubes have tremendous advantages over incandescents. They emit about 3 times as much light as an incandescent (given the same wattage), and the light spectrum is one that plants con use more effectively. However, they do certainly have their limitations. Light is emitted over a large area, so it is not concentrated. Because of this, the lights have to be hung very close to the plants (usually within 2" or so from the grow tips), and constantly moved to accommodate plant growth. This makes garden maintenance rather difficult, even when the lamps are hung on chains. Florescents are, however, very useful in cloning, and starting seedlings. Because in these stages, a plant is not growing vertically very quickly, the disadvantages of moving the lights are reduced. They also put out a more gentle light than the HID lamps, and release less heat. The fact that they produce less heat is very important to those growing in enclosed and not-especially-well ventilated spaces. If you choose to use fluorescents, it is best to purchase the 'cool white' variety. The ones that are sold as grow lamps (including grow-lux, vitalite, etc.) are much less efficient than a standard fluorescent, and just do not put out enough light to be useful. The slightly different spectrum produced by these lamps does nothing for most plants. Some growers have reported excellent results by using a mixture of cool-white and warm-white lamps in a florescent fixture.
Aug 27, 2008 | Sun System 600 Hps Cool Grow Light System...
Hydrofarm Agrosun Dayspot 60w Grow Light Kit Logo
177 people viewed this question
Top Hydrofarm Garden Experts
Craig Butler
Craig Butler
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
