Question about Vivitar V3800N 35mm SLR Camera
I can't see the meter in the view finder? Is
I can't see the meter in the view finder? Is there a meter in V3800N.
  • kakima May 11, 2010
    Yes, the camera has a meter. Do you see a green dot or a red plus or minus sign? If you don't, try a fresh set of batteries.
So if i have the "-" green and red "+" on at the same time my photo is okay?
Posted on Oct 07, 2012
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Yes, the V3800N has an exposure meter.
If the red - lights up, you're underexposed. If the red + lights up, you're overexposed. If the green circle lights up, you're right on. If both the red and green light up, you're within one-third stop of the right exposure.
If you don't see either the green or red lights, then you need batteries. The camera uses two LR44 alkalines or two SR44 silver-oxides. But the only thing that uses the batteries is the exposure meter: everything else on the camera is stil fully functional.
Posted on Feb 03, 2010
Vivitar v3800n exposure meter problems
Check the aperture lever in the mirror box on the side. sometimes it gets bent when the lens is put on wrong. Straighten with needle nose pliers. Carefully, it will break easily.
Apr 03, 2014 | Vivitar Photography
How do i set up eye pieces and focus lenses?? Instruction manual came in chinese with no translation and we are begiiners!
During the day:
1. Point to a far (1000 meters or more) object
2. Insert the lowest power (highest number) eyepiece e.g. 25mm
3. focus on the object.
4. Align finder to match what you see in the scope.
At night.
1. Put scope out and let it reach the temperature of the outside.
2. Point finder to the moon (1st object you should always use to check scope and finder alignment)
3. Use the same low power eyepiece.
4. If everything seems fine, switch to a higher power eyepiece and enjoy the view. You may have to slightly adjust the finder to align with the main scope.
If the views are blurry, the telescope may be out of collimation. Look on the internet for generic collimation instructions.
If this still did not help. Throw the scope out! Its probably a piece of junk and will only discourage you.
Dec 12, 2012 | Optics
Cannot see metering in optical viewfinder
Please, what metering can you not see? The view finder has numerous items to view. If you cannot see anything is the camera turned on, is the battery charged? Next are you referring to the LCD on the camera back. If yes, please go to the Custom Settings Menu number 06, is it off? That is found on page 88 of the D80 manual. If none of that works get back with us with more information or contact Nikon.
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
No light meter on Vivitar V3800N
It may be that the batteries that came with the camera are dead. Double check the way you have them installed, both cells should have the positive side up as they sit in the cap. It is best to handle button cell batteries on the round edges rather than the flat sides. The battery cap for your camera should have open slots on the sides so you can place the batteries in using those openings
Feb 01, 2010 | Vivitar V4000 50MM 35mm SLR Camera
How do I use my light meter on my Vivitar V3800N all I see is a red plus
The red plus means you're overexposed. Increase the shutter speed or close the aperture until the middle light turns on.
Sep 29, 2009 | Vivitar V3800N 35mm SLR Camera
I cant turn off my light meter om my v3800n 35mm camera without taking the batteries out. Is there a way to turn the meter off? Or do I have to take the batteries out every time?
Hello...there is most probably a defective switch on the camera...If you are facing the front of the camera, on the camera body, to the right if the lens is the meter button.(near the flash pc socket) Also, you can check the condition of the batteries by pressing the shutter button half way down. If you see a red or green light, the batteries are good. If not, replace them *both* with silver oxide.
Mar 07, 2009 | Vivitar V3800N 35mm SLR Camera
Vivitar v3800N battery holder missing
rcv7,
this camera has at least two different names that i know of (phoenix, vivitar ) .The battery covers are the same.
most camera repair shops have repair manuals with part numbers from the manufacturer. the only other way is to take a cover to a machine shop and have them make some from aluminum. we had this done for the pentax spotmatic when parts were no longer available.
Jan 14, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
How to turn on the camera
aeloveforev9
all camera's have a switch, button or lever to turn the power on. look through the finder if any light is on or the meter needle is moving then the power is on. some turn on when the shutter button is pushed in slightly. make sure the battery is good and no corrosion is in the battery compartment.
Sep 07, 2008 | Vivitar V3800N 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Internal LED inside camera.
Try using an external light meter.
Apr 30, 2007 | Vivitar V3800N 35mm SLR Camera
Vivitar V3800N 35mm SLR Camera Logo
435 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
