Question about SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811
Label dispensing problem
The label is not dispensing constant.
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Dmx i4308 skipping every other label
emelish: If is constant the print label and skip label, you have adjust the label size in your software. If the label skip is not constant, then clean the label sensor, position it in better place and perform a quick calibration pressing and hold FEED button by 5-6 seconds and release it. Maybe you can do it once more time. Roberto Martinez
Sep 02, 2011 | Datamax DMX-I-4208 Label Printer
When I print my labels, there are lines that run through it
The lines(voids) are being caused by elements that are worn off the printhead. No energy is getting there to release the ribbon, causing a void area. To see the full extent, just create a label, using your widest label, that prints a thick black line. You will easily see the "void" areas as white lines.
This is common over time due to the constant contact with the ribbon. The elements wear down just like the tires on a car from the constant contact with the road.
The only way to correct is to install a new printhead.
Apr 28, 2010 | Zebra Z4Mplus Label Printer
My zebra TLP2844Z can not print because after fiew moments turn on the printer the light button becomes red. How to solv that?
A constant red light usually means the printer is out of ribbon or labels. It may just not recognize the size of the label so try a manual calibration to set the size.
1. turn the printer off
2. press and hold down the FEED button while turning on the printer
3. Keep holding down on FEED until the led flashed once, then let go
4. The printer will do an auto-calibration on the label.
When it's done, pressing FEED should advance 1 label. It's then ready to go.
Hope that helps !
Mar 23, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Video label remains on constantly
On the original TV remote there is a button located just above the "3" labeled "DISPLAY".
Press the "DISPLAY" button a couple times until the label goes away....
Good Luck...
Jan 25, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
PRINTER PRINTS ONE LABEL THEN DISPENSES 4 TO 5 MORE BLANK LABELS. UNABLE TO RESET WITHOUT TURNING UNIT OFF AND REWINDING LABEL ROLL. WE HAVE A COGNITIVE LX THERMAL PRINTER.
Printer needs calibrating. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Oct 10, 2009 | Label Accessories Cognitive Thermal Label...
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Dec 31, 2008 | Avery 9100 Thermal Printer
Label is printing but it is dispensing 4 extra blank labels.
If you are using Avery labels or an euquivalent. Go to avery.com and download and install the labelmaking program. If you are using Microsoft Office software it should integrate into it as well.
Select the correct form from the label making program and the blank labels should go away if there is something to print on them.
Jul 21, 2008 | Dymo Office Equipment & Supplies
SATO M-8485Se Thermal Label Printer Print Engine - P/N W08485811 Logo
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
