Question about Microsoft Office Professional 2007 Full Version for PC
How do I copy macros in word 2007 from one
I have a new computer. I have created many macros in word in my old computer. I need to copy my macros in word 2007 from my old computer to my new computer.
  • 497 Answers
1. Just search for 'Normal.dot' file in your old Computer containing you macro. Copy it..
2. Now search for the same file in your new Computer and replace it with your old Computer's file.
3. Copy Normal.dot from old to new computer and you are done.
Good Luck!!!!!!!!!!!!!!!!
Posted on Sep 28, 2009
Step by step instructions on how to create a macro, create form f
You can create a macro by using the macro recorder to record a sequence of actions, or you can create a macro from scratch by entering Visual Basic for Applications code in the Visual Basic Editor.
Open a new document.
From the Tools menu, choose Customize.
Click the Commands tab and then scroll down in the Categories box and select Macros. You’ll see the names of any macros you've created in the Commands box on the right-hand side.
Click, hold, and drag your macro onto any toolbar and release, as shown in Figure D. A button with the name of the macro will appear on the toolbar.
May 25, 2010 | Microsoft Office Word 2007 Full Version...
How to create macro button in microsoft excel 2007 because
well follow the steps below to get your job done:
To create an option button in Microsoft Office Excel 2007, make sure that you add Option Button (form control) to the Quick Access Toolbar. To do this, follow these steps:
  1. Click the Microsoft Office Button, and then click Excel Options.
  2. Click the Customize category, select All Commands in the Choose commands from list, select Option Button (form control), and then click OK.
To create an option button and to assign a macro to it, follow these steps:
  1. In Excel 2003 and in earlier versions of Excel, click Option Button on the Forms toolbar, and then draw the outline of the button on the sheet.
    In Excel 2007, click Option Button (form control) on the Quick Access Toolbar, and then draw the outline of the button on the sheet.
  2. Select any cell in the worksheet.
  3. In versions of Excel that are for Microsoft Windows, right-click the option button, and then click Assign Macro.
    In versions of Excel that are for Macintosh, press COMMAND while you click or press CTRL while you click, depending on your operating system version. Then, click Assign Macro.
  4. In the Assign Macro dialog box, click the name of the macro that you want to assign to the option button, and then click OK.
When you click the option button, the macro will run.
good luck ...:-)
Apr 08, 2010 | Microsoft Office Excel 2007
How do you copy macros created in Word 2007 to another persons pc?
Just copy the file that contains the macros (probably just a.txt file - if it isn't that open it again in Word and save it as a .txt) to a USB key and from there to wherever you want.
Nov 09, 2009 | Compaq Presario 5000 PC Desktop
Normal.dotm Won't Adopt Macros & Code is Seen as Full of Bugs
It sounds like your Anti-Virus or Spyware is blocking and won' t allow access, it thinks its harmful, try turning off the Virus software installed, do your thing and then turn the software back on. If thats not it then your Software is damaged and you will have to install a new copy of Office. Good Luck.
Oct 27, 2008 | Compaq Presario 5000 PC Desktop
Macro
you can try macro recorder software, download macro recorder software named AutoMe from
http://www.asoftech.com/autome/
May 16, 2008 | Microsoft Office Professional 2007 Full...
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
Can't scan documents to Microsoft Word 2007
Have you tried Alt I P S.
Open word 2007, insert your document in your scanner, and hit Alt I P S. go to advanced and make sure the paper size is correct then ok.
Dec 25, 2007 | HP PSC 1350 All-In-One Thermal Printer
Copying Microsoft Word macros to new computer system
Macros are stored in one of two places, Irene - and you decide where and when you create one. When you select Tools -> Macro -> Record New Macro you’re prompted to either create the macro in the global template (normal.dot) file, or the document you’re currently working on - by default, normal.dot is selected so that the macros are available in all documents you create.
Your normal.dot file is also where all custom styles, toolbars and autotext entries are stored, and it’s possible to transfer all of these - plus your macros - from one machine to another courtesy of Word’s Macro Organizer tool. The walkthrough below explains how to access it and back up your macros to a file you then transfer to your second PC before copying those macros into the normal.dot file on that computer so the macros are accessible from there too.
While this tool is the best way to transfer macros, or other individual elements of your normal.dot file (just select the appropriate tab to transfer styles, toolbars and autotext entries in exactly the same way), if you’re migrating to another PC you may wish to take all your settings with you. If you have Office 2000 or later you can use the Save My Settings Wizard to back up all your Office customisations - including the normal.dot template - and then use the same wizard on your new computer to restore them to the version of Office installed there.
Office XP and 2003 users will find the tool installed with Office -access it from the Microsoft Office Tools menu on the Start -> All Programs menu; Office 2000 users need to download it from here. It’s called the Microsoft Office 2000 Profile Wizard here.
Nov 03, 2007 | Compaq Presario 5000 PC Desktop
Need to Know fully info about Macros
Macro is a simple way to automate tasks in Microsoft Office programs. It allows advanced users to program or create their own commands in Office, thereby automating tasks. For example, a user might want to create a table with four values already in them. The user could create one, and then copy it, and paste it. However, when you restart your computer, that data is lost. Unless you open the old document and copy the table, you'll have to start all over again. Macros helps you do your tasks. By recording the table creation to a macro, creating the same table over and over is just a simple macro away.
Sep 26, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
