Machine is leaking out the front door
LG WM2032HW
The washing machine leaks out the front door and floods the laundry room. Happens intermitantly.
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check door boot seal for ripping/ holes in it
Posted on Sep 28, 2009
Why is my brand new front loading lg washing machine leaking water from the bottom?
Maybe the door gasket is leaking. Maybe an internal connection is leaking.
Feb 25, 2018 | LG Washing Machines
Washer draining on to floor
take bottom cover off and check to see if the drain hose running from the pump is leaking also check the pump sometimes they crack causing a leak
Apr 07, 2014 | GE WSXH208A Front Load Washer
Hot point wm vlsr1090g3ww leaking
Is this a top loading machine? Are you seeing water flowing through the overflow or are you thinking that may be your problem? Asking because I've personally never had a prob with that tube. Leaks have always been attributed to other causes. Top loading hotpoint leaks are usually caused by a leaking transmission seal, water drain pump, inlet valve or faulty pressure switch. Need more info sorry.
Dec 08, 2012 | Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
I put a load of clothes on to wash and left the laundry room and everything was fine. When I returned the whole laundry room floor was flooded! I can not see where any of the incoming water lines or the...
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
Jan 19, 2018 | Kenmore 24832 Top Load Washer
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
LG WM2032HW gasket replacement
I have changed these without disassembling the unit. Just remove the spring from the gasket, then peel back the gasket to remove the inner spring. This is the easy part, getting the inner spring back on is a pain in the neck, but it can be done. The spring will give you problems either way. Good Luck
Aug 14, 2008 | LG WM1814CW Front Load Washer
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
392 people viewed this question
Top Washing Machines Experts
