Question about Cameras
I bought a new memory card and when i insert it I get the message: memory card error. how do i correct this? thanks
  • 687 Answers
Some cameras will not support the later versions of the SD v2.0 released after June 2006 (secure digital mutilmedia card) memory cards that are on the market/
First check the size of the card in (MegaBytes) some older cameras will not even read a SD v1.x 2MB card but will read the smaller 1MB size.
Check for compatibilty with SDHC (Secure Digital High Capacity, SD 2.0) on your camera even though it will fit as it has the same form factor (footprint) as the SD v1.x the camera is not set up to read it and will throw and error.
I suggest that after you have checked all this try and get your money back.
Posted on Sep 28, 2009
Each time i put my memory car in my phone that is a blackberry 9000 i get a message saying " A media card has been inserted that contains errors. To correct the errors please use a disk error-checking...
Hello.
To do that, you need a card reader. Insert your memory card into a card reader, then:
Insert the card reader into your computer's empty USB slot.
Go to "computer" or "my computer".
Right click on the drive of your card reader and choose properties.
Click the "Tools" tab then click "Check now"
Check "Automatically fix errors" and "Scan for and attempt to recover bad sectors"
Click "start" and wait for it to finish.
That should fix the errors. If it doesn't, format your memory card.
Thanks for using Fixya!
Jun 22, 2011 | Cameras
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
Jul 17, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Intializing Card Error Message
Just format your card once your problem will be solved
Jan 21, 2009 | Fuji FinePix A607 Digital Camera
I was brought a coolpix Nikon camaera at the end of March and after buying the correct memory card for it, I always get an error message saying that this card can not be used. I therefore checked that this...
sir did you check you manual for compatibility of your memory card? try to ask the person or the shop were you bought your camera for the right compatibility of your memory card aside from this, ask also the seller of your new memory card about what you bought from them they will assist you.
heres another. if you have a card reader then insert the memory card onto it and format it to you computer before you insert it to the camera and see if its accepting the card. by the way what is your memory card model and you camera?
CHARCOIS
Oct 06, 2008 | Nikon Cameras
Memory Full Error
The problem is with your phone not the memory card. To better solve this problem I will need the model and make of your phone.
Thanks
Jan 08, 2008 | Nokia 1600 Cellular Phone
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
