Where can I get light bulbs for Sansui amplifier system 3000E
  • Audio Player... Master
  • 5,190 Answers
Try Willow Vale Electronics, or CPC, both are online.
Posted on Oct 07, 2009
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
I have a sansui home theatre model no san0310 and everything works but there is no volume coming from head unit, there is no blown fuses
Your unit, most likely has a condition known as DC Offset(a damaged amplifier) The microprocessor(computer inside your Sansui), with with the condition above, will not allow any sound until it's repaired. If you are interested in having your Sansui repaired, please visit my website at audioserviceclinic.com. BTW, I was a Sansui authorized service center for over 20 years. Thank you.
Sep 04, 2015 | home Audio Players & Recorders
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
Can I connect
Sansui A-80 amp already have the preamp like what
the Sansui C-77 have.
• Sansui A-80 amp could be over-driven with C-77 ,
watch for the volume level.
But you can connect it as an alternate room equalizer
if you need to.
Jul 26, 2012 | Sansui Televison & Video
9900z sansui power amp parts
Hello
The spare parts for most of the audio systems are available from most of the electronic spare part selling shops at your town. If you feel any difficulty it getting the parts, you can contact the nearest authorised service center for Sansui at your town. OK.
Jan 24, 2012 | Audio Players & Recorders
Standby light is flashing on my marantz sr7001
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the Standby blinking (protect) show or not . if not, then any of the speaker is damaged also check the wire for any short circuit . If then also its goes to protection then it have some hardware truouble inside.
Amplifiers gose protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally amplifiers show this when any of the output amplifier have some problem. there 6 amplifiers in this receiver . May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
For that you need digital multimeter,soledring iron screwdrivers etc
Open the amplifier , then power it on. Connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). Then connect the positive terminal to all the output transistors emitter pin one by one . The voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than +/- 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
After replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. Put the bulb in a holder. Now you have two wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim ,then remove the power , remove the bulb insert fuse and connect the power and check.
(If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components
OK
Aug 20, 2011 | Marantz SR7001
My lamps have failed in my sansui a80 amp, the bulbs are as rare as rocking horse sh1t and would like to replace them with leds the 2 bulbs are rated 3watt 8 volts
sure u can. 8v 3 watt means about 400mA current. most leds will light up with only about 20mA, so use a series resistor between 220 ohms and 330 ohms each . less resistance will give u more brightness, too low - the led will burn.
Apr 07, 2010 | Audio Players & Recorders
Anyone have a car remote starter model OF-3000E my transmitter doesn't work anymore.
yes i have 1 brand new in the box ,, model on- start of-3000e ,, dont know wath year it is but never instaled ,, brand new in the box ,, and for sale ,, make me an offer..
Oct 19, 2009 | Vehicle Parts & Accessories
I have a Sansui AU-717 Integrated Amplifier that needs some work done on it. Is there a Sansui service center in Washington State that can work on this?
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Apr 13, 2008 | Audio Players & Recorders
Spares
Bass Treble,bal controls can be clened with contact cleaner.
Drive belts audio heads may be available at the sansui web site or mcm electronics.com.
GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
85 people viewed this question
 Grubhead
Grubhead
