Question about Makita DPC7321 14" 73cc Power Cutter
DPC7311 WILL NOT START . GETTING FIRE & FUEL,COMPRESSION SEEMS FINE
    Problem Solver:
  • 12 Answers
Check compression with a gauge bet its under 100. if so check piston and rings, Most of the time you can just hone cylinder and replace rings.
Posted on Oct 05, 2009
On a 1990 honda acord, i did the head gasket and now it wont start, i ch ecked the timing marks again and everything lines up, i took off the fuel line and it seems...
To fire the Gas, you need Compression (Have you checked the Compression)...
Spark
Fuel (Injected requires 40 PSI)
Provide more information please
Apr 09, 2013 | Honda Accord Cars & Trucks
89 camery no start , has fuel p.s.i. , injectors fireing , spark on all plugs , compression even across
Have you checked cam timing?If it has jumped a tooth or two it will not start.
Jun 18, 2017 | 1989 Toyota Camry
Have a makita gas cut-off saw dpc7321,has spark to the plug but will not start,it is getting plenty of gas too
Is the gas fresh? Is the plug wet with fuel after you try and start it? Have you done a compression test on the engine?
Jul 09, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
I replaced fuel line from carb to intake and now it wont start?
Check the carb fuel stub to see if its seated in the hose. Chech to see if you re-installed the piston underside scavenge hose to the bottom stub of the carb. Check your compression. New is 160 psi, operational but problematic (hard start) 130~140 and completely toast at 90. This saw is easy to flood when compression has fallen off. Cold start, 3 pulls choke on with the throttle trigger locked wide open. At first sputter, put choke in normal run and it should fire by the 3rd pull. If not its flooded. Then remove the plug and with an air hose vacate the cylinder of fuel for a few minutes and try again without the choke or throttle lock set at wide open.
Good luck.
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
Miss fire in cylinder 8 . already replaced plugs & wires
is there spark coming out of coil when running? ck compression? and then the fuel injector is next on the list. have a shop that has a tech2 scanner check it, or they they can do a "injector flow test" and see if its opening and flowing when commanded, could be plugged.
Oct 19, 2009 | 2002 GMC Yukon XL
2003 chevy malibu wont start
If you have spark, and fuel , and still no start, I'd first pull out the spark plugs and make sure they are not fuel fouled. Dry or replace as necessary. Do you have compression ?
Apr 11, 2009 | 2003 Chevrolet Malibu
My truck is getting fuel but wont start
Three thing and engine need to crank are fuel fire and compression so if you have the other two then you are losing compression i would suggest running a compression test on it. I hope that helps you out.
Nov 25, 2008 | 1991 Chevrolet S-10
Gets gas and spark still won't start
Sounds like this maybe a timing belt has slipped (no Compression) if the engine seems to turn over faster than normal you should or the engine is not getting fuel you can use brake parts cleaner spary in intake and see if it fires up if it does the engine is not getting fuel - possible fuel pump
Sep 27, 2008 | 1991 Toyota Camry
Makita DPC7321 14" 73cc Power Cutter Logo
699 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
