Question about Sanyo DP42746 42 in. Plasma Television
Qam tuner i have a vizio and this sony lcd tv, why does the sony not pick up digital signals from cable?
    Genius:
  • Sanyo Master
  • 1,689 Answers
For most cable services, you need their decoder box to have the digital and HD services.
For the Sony HD TV, you will get best results with an HD cable box, and use the HDMI cable interconnect with it.
Call your cable company for details.
Jerry G.
Posted on Apr 13, 2008
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
Sep 08, 2014 | Televison & Video
Does my tv model#VS 420LF1A have a digital tuner
Yes, the Vizio VS420LF1A has digital tuners (assuming the TV wasn't damaged or altered). It has both an OTA (ATSC) digital tuner and an unencrypted cable (QAM) digital tuner.
For more details of the specs, see page 66 of the following pdf: http://76.254.74.102/Updated%20User%20Manuals/Vizio%20Amtran%20User%20Manuals/VS%20Series/VS420LF1A%20User%20Manual.pdf .
I hope this helps.
Sep 11, 2011 | Vizio Televison & Video
I just purchased a used Sony KDL-V26XBR1 that cannot tune the digital channels over our cable or any signal on the over the air input. Our Samsung, same vintage on the same cable can tune the digital...
Greetings - Your Sony has the standard tuners for a current HDTV, NTSC (analog), QAM (cable), and ATSC (digital/HD) broadcast..
There's something going on with the Sony TV. It's a pretty high end TV so it might have some additional features that require you to do something different (I doubt it) but make sure you've been through the manual.
If you didn't get one with the TV you can download a PDF version HERE.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 12, 2011 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
How do you get the tv to search for digital channels
I need more info! How old is the television? when you say "standard" do you mean standard definition? CRT or "tube" model?
Older model TVs with the NTSC tuner will NOT pick up the digital over the air signal, you need a TV with ATSC/QAM tuner built in, or a set top box.
Dec 08, 2010 | Sony Televison & Video
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
How can I connect an ATL850 8.5 in. LCD TV to a cable box?
You have a ATSC Digital tuner in your set which accepts over the AIR digital transmission. Your set does not have the ATSC QAM tuner to receive digital cable transmission. Those size sets are usually designed for outdoor use with an antenna and for camping ect.....Outside of that, go ahead and connect it and see what happens...Do auto program.
Jun 07, 2009 | Lasonic ATL850 8.5 in. LCD TV
Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Feb 06, 2008 | Televison & Video
Sanyo DP42746 42 in. Plasma Television Logo
97 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
