Question about Garden
My 21 HP diesel zero turn mower starts blowing black smoke after running at higher throttle settings and temp gauge shows engine is warm. No air restrictions. New fuel filters. smooth running when cool or low throttle setting. Smoking starts suddenly and will eventually stall the engine if left to run at high throttle setting.
  • 291 Answers
Looks like you've got a good idea on what makes diesels smoke, so I'm sure you know that black smoke is almost always from too much fuel for the air that's going in. So it can be too much fuel or too little air. If your filters are good, the next things to check are the fuel pressure and the injectors.
I know diesels, but I don't have any specific experience with lawn mowers (kubota?). Since it stalls eventually, it sounds like it's not a single cylinder (although not for sure) so I'd check injector pump first.
Posted on Sep 28, 2009
I have a 46", 21 HP Craftsman riding mower. The
perhaps it is no oil or too much oil. Check oil level!
If it was too much it would be blowing oil or blue smoke out the exhaust.
Good luck! Hope this helps.
Ashman
Jan 03, 2011 | Craftsman 21 HP 42 in. Zero Turn Tractor...
24horse vtwin runs good at half throttle seems to lack power.turn on the mower deck and sometimes it runs ok but will not mow normal lenth grass not much power.if i turn the throttle up wide open it will...
Sounds like you're getting enough fuel (black smoke) Could be running on only one cylinder. Either stuck valve or loose valve adjustment or one bad magneto. You could try starting with one spark plug disconnected. If it doesn't start, reconnect that one and disconnect the other. IF it runs like it was, then you're running only one cylinder, and go to work on finding out why.
Aug 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Blows black smoke when running 2600 rpm and boost goes down
I assume its the 6.0L diesel...If so sigh......double sigh.. I had one of these...triple sigh. I need a bit more clarification. How many km on the engine/vehicle. Also, you say that it blows black smoke while running at a constant speed at 2600 rpm, or while you are accelerating to 2600 rpm. Also, when you say the boost goes down, does it decrease by itself, or when the throttle is let off. The boost naturally goes down when the throttle is released (not trying to be a ****, i dont know how much you know). However, if the boost is going down by itself, while the engine is under load (its not supposed to, it should stay constant) it could be a couple of things, which "can" contribute to black smoke. If there is a leak anywhere from the turbo to the intake of the engine, it will cause the engine to get less boost, which means less air into the cylinders, which means black smoke. Check all of the connectors/tubing coming from the turbo to the intercooler, and from the intercooler to the intake manifold and see if there are any problems. The more costly problems which results in boost going down, and black smoke, deals with a problem with the wastegate on the turbo (controls how much boost is produced, and when too much is being made, it will bleed off excess pressure). So if your wastegate is malfunctioning, your boost will go down and you will get black smoke cause the engine is not getting enough air. also, around 160km...80mi, the injectors "can" start to go on the 6.0L diesels....I would check the turbo for leaks, the tubing for leaks, and the intercooler for leaks (a big rock can punch a hole in radiators and intercoolers...intercooler will be in front of the radiator). I hope this helps
May 29, 2010 | 2005 Ford F 350 Super Duty
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
2004 Tahoe Heater Problem
check coolant level ,must be low ,chck for coolant loss
Mar 04, 2009 | 2004 Chevrolet Tahoe
2004 Chevy Tahoe. Heater working only at higher speeds.
you have air trapped in the cooling system. A good indication is that one or both of your heater hoses going into the heater core are cold when they should be hot.
Park facing uphill, raise front of vehicle so radiator cap is higher than top of engine. (You want bubble to get to radiator and out the cap.)
Leave cap on but loose, so bubble can purge.
Turn heater on.
Fill radiator and reservoir with 50/50 mix of antifreeze.
Start engine and run at about 1500 roms until the engine warms up and thermostat opens.
You will know themostat opens when top radiator hose is hot indicating coolant is flowing.
Shut off engine.
Fill radiator and reservoir. Install cap.
please Rate as fixya if this works. good luck
Mar 04, 2009 | 1997 Chevrolet Tahoe
Intermitant temperature
Check to make sure your thermostat works right by monitoring the warming up of your engine. With a completely cold engine, start and run the engine for a few minutes, then put your hand on the top radiator hose to monitor if and when it gets warm as the thermostat opens more and more and note the gauge reading( if it works) the top radiator hose should be unbearably hot within 5-8 minutes. If the therm. opens right it should close right aswell, staying open a little while eventhough the radiator may have cooled may be what you are experiencing causing the rapid cooling and is nothing to worry about. The Hose should not get warm very soon after starting the engine. Regarding you gauge, lets take one step at a time, verify proper op. or the therm.
Jan 20, 2009 | 1986 Toyota 4Runner
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Garden Logo
324 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
