Question about Whirlpool GU2400XTP Built-in Dishwasher
Won't wash THE WASH LITE GOES ON BUT NOTHING HAPPENS I DO HEAR A MOTOR TRYING TO START THEN CLICKS OFF
    Novelist:
  • 148 Answers
Fill valve could be bad. that or a timer.
i am guessing that gerty is your name, and 1955 was your birth year. if true, that suggests you are not going to get a voltage tester and go after testing the solenoid valve for current. i am from 1951, and i would not do it either. bad back and knees, and would rather have a service tech do it.
you also could have a door switch that is bad, but not likely as the pre wash drain out cycle does appear to start.
good luck
mark
Posted on Dec 28, 2007
Whirlpool Cabria: Power is getting to machine, but when you hit start button...nothing happens.
Sounds like something is jammed and overloading the machine. Check for locked motor.
Dec 21, 2017 | Whirlpool Washing Machines
WTW 4800XQ1 not working. Start lite goes on, fill lite goes on, then start lite goes off.
Hello. When you press the start button, you should hear the lid lock engage, then disengage after a short pause, then re-engage. If this doesn't happen, the lid lock might be defective, (the locking, unlocking, then re-locking is a self test). The motor should make some short, slow spins to determine load size. Listen for the motor--if all you hear is a "pulsing faint humming or buzzing noise", there is a part failure causing the motor to not move correctly. Because of the electronic design, you will have to call for service to determine the failure cause.
Aug 19, 2015 | Whirlpool Washing Machines
Where i can find elecrical wiring diagram
When you try to start the bike, does anything happen? Noises? Clicks? Or is it silent and nothing happens? If you hear a click or it try's to start but doesn't turn over. If nothing at all happens when you hit the start switch then you most likely have an electrical issue, versus if you hear the starter click or try to start to bike, then that would mean a mechanical issue.
May 14, 2014 | 2008 Peugeot Geopolis 400
Machine wont spin
check motor brushes or blocked pressure chamber.
Feb 09, 2014 | Hotpoint Aquarius WT540 Front
Whirlpool WFW9150WW00 won't start after tripped circuit breaker
the motors internal fuse link may have burned thru..this is not a user serviceable part.. calls for another motor..
Jan 12, 2014 | Whirlpool Washing Machines
The dryer won't start. Tried to hard reset, but it still will not start. You can hear it clicking over, but nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
2007 chevy cobalt ls won't start battery good starter good turn key nothing no click nothing all lites work on dash and radio works jumped starter with screwdriver turns. Over but won't start...
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Jun 06, 2011 | Chevrolet Cobalt Cars & Trucks
Kenmore washer
if you hear a motor running sound then that it is the coupling between the motor and transmission. if it is only a clicking sound then it might be a bad motor.
Jun 25, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
41 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
