Question about Kenmore Dryers
Kenmore dryer, 110.68972890, won't start, no heat. drum will turn if P-T-S is held but still no heat.
3 Suggested Answers
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 1122 Answers
SOURCE: Kenmore dryer 68972890 won't stay running
it sounds like a weak motor.you can also check the start switch if you have a meter,remove both wires and check it on ohms in the off an on position-mike
Posted on Mar 11, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
Kenmore series 80 electric dryer won't heat
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
May 28, 2012 | Kenmore Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
I have a Kenmore Elite 8528009 The dryer will only stay on if the start button button is held in, I clamped it in to dry the clothes already in the dryer, the drum will spin but there is no heat. It was...
heatman101
Sep 25, 2010 | Kenmore Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Kenmore Elite 73942 Gas Dryer only runs with start button held
Unplug the dryer. Open the control console.Mark and remove the wires from the start switch.
Using a volt meter set for continuity,touch meter leads to R1 and R2 while pushing the switch. No reading is a bad switch.
Touch meter leads to R2 and CT1. No reading is a bad switch.
If the switch checks out good the start windings in the motor are bad.
Dec 27, 2009 | Kenmore 73952 Gas Dryer
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
