Burning smell when I turn on machine to start washing
When I turn on the washing machine, the water starts but does not seem to fill up. Then I start smelling a burning smell. How can I repair this?
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Your heater is coming on with no water in machine hence smell sounds like pressure swith is jammed on depending on make could be blockage in pipe making switch think water in machine swith on heater...Remember electricity can Kill...proceed wit h caution....Find hose and give it a clean check also chamber
Posted on Sep 28, 2009
3 Suggested Answers
  • 1314 Answers
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 20, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore 70 series washing machine filled up with
check the belt/coupling for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Burning smell while washer fills
Sound like something else isn't turning because it's jammed
the the motor is trying to turn.
May also be the starting capacitor.
Oct 16, 2013 | Maytag Washing Machines
Kenmore 600 series washer
if the water fills up and starts have a burning smell, to me it sounds like the agitator motor is bad. Which would be the next part in the washing sequence.
That's the best I can make of the description
Appliance repair person would be who to call
Aug 15, 2013 | Washing Machines
Every time i start the machine it keeps filling with water and won't stop then there seems to be a burning smell wot is the problem? its a indiset we125
Sounds like it could be a sticking inlet valve, or the pressure switch is not working that controls the water level, could be a blocked pressure chamber, this is located at the bottom rear of washer.
Jan 16, 2010 | Indesit WA 125 Front Load Washer
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
Nov 26, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer
THE SMELL IS THE BELT BURNING,YOU CAN REMOVE THE FRONT PANEL TO CHECK THE WATER PUMP,CLUTCH,BELT, AND TRANS,SOMETIMES THE BELT WEARS AND JUST STARTS SLIPPING.,LET MW KNOW-MIKE
Oct 19, 2008 | Maytag Performa PAV3200
Model# LW6163WM/LM washing machine
Dear usaguitarman Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, washer fills with water. then the motor overload protector starts clicking
in and out.and there is a burning smell. I am able to spin the water back out.
The belt needs to be replaced but I don't know if that could cause my problem.
Yes I believe the belt could be the problem!
That is more than likely the burning smell!
Change to belt.!
While your at it, unplug the machine for 5 minutes or more and then it will reset the system too!
Let me know how wonderful it performs after these repairs!!!!!!!!!!!!!
i believe you will be fine!
Bless You,
Huuum
Please do not forget to enter a rating when you are done.
Thank you
Sep 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Atlantis MAV6451AWW
turn off the water and remove the hoses from both the wall and from the back of the machine. check the screens inside of the machines water valve, they are probably clogged. do the same for the hose screens on the other end. replace the hose screens at the wall end and remove the screens from inside the machine. replace hoses and turn the water on and you should be good to go
Sep 19, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
342 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
