Paper grabs to one side while printing - Office Equipment & Supplies
SOURCE: Paper does not feed - GRABS RIGHT SIDE
I once had a similar problem a few months ago and I tried EVERYTHING I could do (Without shaking the printer, I was scared to do that) nothing worked, till I actually got up on a chair and looked into my printer (It is up on a rise above my computer) and there was a push pin sitting in the feeder opening! (Remove pushpin = then it was fine)
Then it started doing it AGAIN yesterday at a time when I really needed my printer, and this time there was no obvious pushpin or any obvious obstruction. I read all the stories here and thought *WOW they had things that far in there?!" So I tried harder and FINALLY after opening the back panel I saw with a flashlight there was a FROOTLOOP (I don't even HAVE any frootloops in my dorm! XD) jammed in the right side inside it! With a chopstick I was able to get it out and now it's fine again. OMG.
But yea, things like to get stuck in printers I guess. XD
Posted on Apr 02, 2008
  • 31 Answers
SOURCE: lexmark x1270 paper jam
hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
Posted on Dec 07, 2008
d2704
  • 101 Answers
SOURCE: grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Posted on Mar 06, 2009
APremkumar
  • 564 Answers
SOURCE: when printing, paper grabs on one side.
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 23, 2009
SOURCE: won't print paper grabs to one side and won't feed
there is a small handle knoc in side the paper out passage pushed towards sign 'envelope' pull back it to sign 'A4 size'. This may surely solve your problem.
Posted on Jul 04, 2009
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
The rollers won't grab the paper. It may grab toward the end of the print job so that the second half gets printed on the top half of the paper. Or it just won't grab at all.
Dear User,
Your Printer rollers seems to go plane, and they are unable to grab paper properly. You should clean them with a clean piece of paper.
And you can also rub silghtly them with an ambry paper, if needed so that it may grip the paper properly.
Thanks
Jan 23, 2010 | HP Officejet J5780 All-In-One Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
The rollers grab the right side of the paper and then jams
the gears which r pulling the paper r slightly worn out or getting blocked by dust particles.
you look carefully where u install the paper for printing there is a black colour round rubber gear with white colour part like a tiny stick attached to it.just check if that part is broken.if yes you have to replace that part.
Oct 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip6000D
hi,
use good quality paper for printing. clean the feed roller or get the printer serviced from the authorized dealer.
thanks
Aug 09, 2008 | Canon Pixma iP6000D InkJet Photo Printer
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
Paper pull only from the right side
take a look as it is grabbing the paper
1- either there is someting blocking the path or
2- the tires need to be changed, not grabbing the paper but instead it is slipping.
Dec 30, 2006 | Lexmark X4270 All-In-One InkJet Printer
42 people viewed this question
jasbo
jasbo
