Question about Microwave Ovens
Cannot remove blade from unit base of a Nutri Source Juicer Model 1000.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You'll need to remove the juicer lid first and then the tightener fixed on the blade. After the tightener is removed you can remove the blade. Please see this exploded view of your Nutri Source Juicer, this will help you to remove the blade--
Please click on the picture to zoom in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
I've lost the instruction manual on the nutri scales. Where can i get a new copy
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 17, 2011 | Microwave Ovens
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
Mar 01, 2011 | Kenmore 80492 / 80494 / 80499 1000 Watts...
Dear sir/mam im having a philips comfort juicer/blender of model no HR 1720,can u please suggest whre i will get a small pot whch wl get attached in this model?for your kind information model HR 2000/70...
It is not possible to attach extra units that can mesh with this juicer than the reccomended attachments that is available.Contact philips appliances dealer close to you.
Sep 29, 2010 | Microwave Ovens
Hi! I dont know how to clean up my Juguera Moulinex Juice Extractor Type 140.6.03. Please help me thank you very much all the beest Med
Hi- I have been having the exact same issue and I couldn't find a solution until, after a LOT of searching, I found this picture of the original tool that came with the juicer and is used to extract the blade. https://dl.dropboxusercontent.com/u/17811633/original-moulinex-tool.jpg
Someone had already mentioned in a different forum, putting the prong of a fork in the hole of the blade and turning, but I had thought they meant turn the fork in the hole, which had not worked, but actually they meant turn the blade. After seeing that picture I understood how it was meant to work. I used a pair of scissors, one prong in each hole, I twisted, and after initial resistance the blade came loose, and I was able to unscrew it. Seeing as 49 people have viewed this problem, I decide to post the solution here as I am obviously not the only one who has had this issue - but it's the typical thing people search for when they have the problem but no one bothers to then post the solution - so I hope this helps everyone to be able to use this fantastic old juicer!! :-)
Sep 28, 2010 | Microwave Ovens
I have a Welbilt juicer and I can't get the top off. That is the part with the strainer in it. JE200 Model 65F5 E138553
Try using a warm to hot cloth over area that is sealed. Do not submerge in water if this area of juicer has electrical components. If it doesn't have electrical components in this are, then hold upside down in sink with small amount of hot water covering sealed area of top. before removing from water, make sure u have a towel handy to set it on, dry with towel before flipping upright. try removing seal/top then. Hope this helps.
Sep 12, 2010 | Microwave Ovens
Could you please explain how I can remove the motor from the casing of my Delonghi coffee grinder model DCG-2. As far as I can see I need to remove the s/s cutting blade....is this a press fit or...
Is your unit still under Warranty? If so, your warranty will be void if you do any kind of maintanence before contacting the Customer Service Department first. What area do you live in?
Jun 02, 2010 | Microwave Ovens
Motor works but doesnt turn spindle with blade on it
you may have (probably) put something in there that wouldn't chop or grind, and the blade wasn't able to turn. When this occurs, a safety feature called a 'shear pin' breaks. The shear pin passes through on side of the base of the blade, through the motor shaft, and out the other side of the base of the blade. The pieces of the shear pin have to be removed, and replaced with a new pin. A common roll pin of the appropriate diameter should do the trick. Bear in mind the shear pin is a 'pressed fit', so removal of the old bits may be difficult. But it can be done.
Feb 06, 2010 | Microwave Ovens
Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
