2002 Chevrolet TrailBlazer Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver side passenger window won't raise back up
Pressed the button to lower the window. It made a creaking noise as it was lowering. I pressed the button to raise it back up but it would not go back up. For a moment you could hear a sound like it was trying to work, then silence.
Turned the car off to see if it would reset the switch. Tried to raise it nothing. Press to lower the window and it lowered all the way. Tried to raise the window again and it only went up about a quarter of an inch from the bottom. Help, the are calling for rain today!
Stacie Wagle
Level 2:
Habit-Forming:
  • Expert 41 Answers
  • Posted on Sep 29, 2009
Stacie Wagle
Expert
Level 2:
Habit-Forming:
Answers
41
Questions
Helped
22529
Points
123
It is either the motor of the switch. Operate the switch while listening where the sound is coming from in the door. Then while you are trying to raise the window, hit the interior door panel with some force, not enough to break anything, but hard enough to contact the motor. If it is binding it should allow the window to raise. If it is trying to raise it is probably the motor.
Passengers side electric window doesn't raise when toggle is pressed on main panel
if passenger window switch work passenger side window and driver side master switch dont. master switch either locked out or master driver window switch is bad.
1988 Mazda rx7 window won't raise or lower
Its either the switch or the window regulator. They all 'live' on the passenger side by the way. I have had both replaced on passenger side over the years on my '88 convertible and guess what? Passenger side window decided not to go up today..down yes..up no so I hope its just a switch. She goes into the hospital Monday. Good luck with yours.
2005 Nissan Frontier LE....The Driver side window will not go down or the rear passenger side. The passenger side will go down with it's own switch but not the driver switch. The driver side switch will...
The problem is that you probably have pushe dhte rear window button thinking it wasthe front window button. Have you ever pushed the rear window button thinking it was the front and then push harder. Inside the switch ther are little plastic pins. Open the switch and turn the little pns around and you should e fine. you cna e-mail me if you like and I can tell youhow to fix [email protected]
15helpful
The power windows are not working on 3 doors. What could be the problem? Just had a dead battery and jumped it off.
Most likely the RX lost the ECU program/ configuration. Need to reset the config. It is a sequence of buttons that need to be pressed.
You have to do the exact sequence of each door as it blinks or you cannot use your windows. Here are the steps.
first the driver window button will blink. lower the window half way down then raise the window up to max and hold the button for 5 seconds. Then the front passenger window button will light up and you do the same thing for each door as it lights up. It goes driver, front passenger, rear passenger side then rear driver side then do your sunroof by hitting the tilt button hold for 5 seconds and that calibrates all the windows.
2004 Grand Am Coupe Passenger Window Problem
Yes you will have to replace switch on drivers door. That is where the problem is.
1helpful
2003 F250 Power Windows won't work
check fuses 35 & 41 (10 amp, red).
it also shows an accesory delay relay in the fuse panel.
And fuse 601? 30 amp.
make sure you don't have lock-out on driver switch panel activated.
Power Window System
Features and Operation
NOTE: The accessory delay feature will allow power window operation up to 10 minutes after the ignition is off or until a door is opened.
If equipped with power windows, the window control switch (14529):
  • will operate the power windows only when the ignition switch is in the RUN or ACC position.
  • is located on each front door trim panel, and Crew Cab and Excursion rear door trim panel.
  • may be used to raise or lower the driver side, passenger side and rear windows from the LF control on the driver side, or the passenger window from the passenger switch.
  • includes a one-touch down (OTD) feature for the driver door window.
  • can partially lower the driver side window when the LF window control switch is depressed half way (first detent).
  • will completely lower the driver side window when the LF window control switch is fully depressed and then released (second detent).
Power Window System — Modes of Operation
There are two modes of operation for the power window system.
Manual Mode
When the LH window control switch is pressed to the first down position, the window will move down until one of the following conditions are met:
  • The LH window control switch is no longer in the first down position.
  • The LH window control switch is pushed to the OTD position, causing the windows to enter auto mode.
Auto Mode
Auto mode provides the OTD feature. The OTD feature is activated when the LH window control switch, for the LH window, is pressed to the second down position.
Auto mode will be terminated when any of the following conditions are met:
  • The LH window control switch is pushed to the UP position.
  • The LH window control switch is released (OFF position) and then moved to the DOWN position (first detent) or OTD position (second detent).
  • Note: Delayed accessory feature must be active.
The OTD feature is controlled by the window control switch.
Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • LF window control switch.
  • Accessory delay relay.
2answers
Passenger side auto window does not function - Toyota Camry 1996
I have fixed these a lot. Almost always it is the button has trash in it. Take it out if you know how and clean it. Or you can get a can of compressed air , like is used for cleaning keyboards, and blow out the trash in the switch.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
