Question about Water Pik pik Original Shower Massage Sm 651
We have an old waterpik shower massager that was made before the current flow restrictors were put into place. The massager head on a hand held has lost about 40% of its power. How can I take apart the sealed head unit without breaking it?
  • 659 Answers
SOURCE: Need assembly diagram for original Waterpik Shower
You just need to figure out which one you have and the manual should be on this site. If its not then give them a call.
http://www.waterpik.com/customer-service/instruction-manuals.html
Posted on Apr 03, 2009
radar001
  • 1051 Answers
SOURCE: I have a WaterPik shower head that keeps coming
If your unit has a threaded connection for the handle and hose the threads are most likely stripped. You can get thread grip material at most hardware stores and repair it yourself. Otherwise replacement is necessary.
Posted on Feb 21, 2010
jeff_drakesr
  • 155 Answers
SOURCE: waterpik shower head came apart at the water
Try this link its a PDF. http://www.waterpik.com/shower-head/install-shower-head/metal-pivot-ball.pdf
Posted on Mar 31, 2010
  • 54 Answers
SOURCE: how can i adjust the height of my shower head?
This usually means removing part of your wall,and extending your pipe ,but if you don't want to do that ,I believe home depot,sells a shower arm that adjustable ,to raise or lower the head
Posted on Apr 13, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Waterpik "2 in 1 Shower System" with
The bracket should get tight on the existing pipe.....if the bracket will not turn and get tight then the threads are stripped on either the bracket or the end of the pipe...
You may be able to get it to get tight by wrapping some teflon tape on the pipe threads before turning on the bracket...the bracket should then go on and get tight enough to hold the handle shower head...
heatman101
Posted on Jan 16, 2011
Little used shower system (rain head, hand held and body nozzles) now has very reduced pressure. was fine 6 months ago when last used.
Pull it apart and see if the flow restrictor is plugged in the water inlet to the shower head.
Nov 09, 2016 | Home
What could be rattling inside the hand held shower head
It sounds like the flow restrictor may have come loose and be rattling around in their. There is no way to open that shower head that I am aware of. If it really bothers you, buy new one.
Oct 28, 2015 | Moen Home
I need to put back flow restrictor in Grohe shower head due to drought, how do I do ?
are you sure that is where it needs to be . as I have never heard of them being attached to a shower head . usually they will be put on the main water inlet line to the home or business
Jun 21, 2015 | Grohe Home
There is very little water coming out of the head. how do i take the head off
Check out the connection line to the hand held shower. Take it appart and check out the screen and make sure it is clean. Also there is a dime shaped restrictor that reduces water consumption down to 1.6 gals. You can remove that plate and the water flow will increase. The head on the shower itself you can soak it in vinegar to clean head up.
Hope this will be of some help yo you thanks.
Mar 26, 2011 | Hansgrohe Interaktiv 2-Jet Handshower,...
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
I have the Eco Rain showerhead and about half the nozzles are no longer putting out water. How can I clean them out?
Disassemble and soak it in a lime cleaning solution or vinegar. I have include a link below with more information for you. I hope this will solve your problem.
http://www.wikihow.com/Clean-a-Heavily-Clogged-Up-Shower-Head
Jun 16, 2010 | Water Pik WaterPik& Ecoflow Hand Held...
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Water pressure drops after a few seconds to almost nothing...
In the hand held shower head where the hose attaches to shower head. In the head there could be a flow restrictor. It may be rubber or plastic. In some cases you can remove it, or check if something is blocking it. Also try running the shower without the head on to see if there is some debris in the hose, and to check your water flow.
Jan 29, 2009 | Water Pik Waterpik& Elements& Handheld...
Water Pik pik Original Shower Massage Sm 651 Logo
651 people viewed this question
Top Water Pik Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Water Pik Health and Beauty Expert? Answer questions, earn points and help others
