Question about Kenmore 24032\24036 Top Load Washer
It is filling with water but then it stops. I can't get it to complete the rest of the wash cycle. I had it on the 'Normal' wash cycle and tried turning the selector to Permanent Press or any other cycle to see if I could get it to engage, but it still did not work. Any help will be appreciated!
  • 61 Answers
Check your lid switch
Posted on Sep 28, 2009
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Samsung WA80v3 connected to cold water supply. Does it heat water during wash cycle or does it have to be connected to hot water supply if heat is required?
It will heat the water as normal, even though it is a cold fill only washer.
Just select prog as normal, washer will do rest.
May 18, 2011 | Washing Machines
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
First became aware there was a problem when machine overfilled resulting inj flooding,cold water fill would stop when i turned on a tap ,suspected water pessure switch.new water pressure switch fitted...
If it works O.K. in a different wash cycle, then the timer could well be the issue.
Using that last cycle you described, will it perform a complete normal cycle ???
Jan 05, 2010 | Washing Machines
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Frigidaire Washer - FTF2140FS1 - fills with water, but won't complete cycle
The water level sensor or float switch may be faulty. If the unit does not sense that the water is at the right level nothing will happen.When the water filling rate appears very slow, the inlet water filters may be clogged. Although not that common the inlet solenoid valve can jam and only partially lift.The cycle timer or program circuit board may be faulty
Jun 02, 2008 | Frigidaire Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
