Question about Garden
I ran the saw without oil in the gas it is not
I ran the saw without oil in the gas it is not locked up but it won't start
  • dontbother10
    dontbother10 May 11, 2010
    I think if you remove the sparkplug and muffler and examine the cylinder you will find parts of the piston adhered to it. How long did you run it? Did it stop running on its own? Did you buy it from a big box store? What is the model number and serial number? Please respond with a clarification below.
  • dontbother10
    I think if you remove the sparkplug and muffler and examine the cylinder you will find parts of the piston adhered to it. How long did you run it? Did it stop running on its own? Did you buy it from a big box store? What is the model number and serial number? Please respond with a clarification below ↓.
    President:
  • 2,220 Answers
Please respond with a clarification below. HTH
Lou
Posted on Sep 28, 2009
  • 157 Answers
What kind of oil did you mix with the gas. and how lond has it been since you ran it. and did it quit while in use. thanks jd
My cutoff saw won't start, compression is good, has oil/gas mix, gets spark from wire but sparkplug was dirty so i cleaned it and she still won't turn over
If the saw briefly runs when you prime the carb and/or cylinder with gas then most likely fuel is not getting thru the carb. Try rebuilding the carb and replacing the fuel filter first. You can also search on youtube and google for troubleshooting tips.
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
Saw was run with stright gas and no oil mix. it cranks but does not start. is there a thermal protection on this to keep from locking the motor up. if so where is it, if not is there a way I can repair the...
If the saw ran without oil, it may be that the ring(s) have stuck in the piston groove due to metal transfer from the piston into the ring groove. Sometimes you can see this by removing the muffler and looking into the exhaust port--the end result is no/poor compression=no start. If this is the case you will have to disassemble the saw to replace the rings & the piston.
Aug 10, 2010 | Echo CS400 18" Chain Saw
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Used wrong gas can and ran saw on pure gasoline.
if your saw didnt lock up ,or overheat it should run again, take out spark plug, with switch off, put your thumb over the hole and check for compression when you pull the cord. if it pops your finger off the hole you probably didnt cook the rings, or burnt the piston, the raw gas may have washed the cylinder down enough to temporarily lose compression (lack of oil seal). refill tank with proper gas/oil mix, squirt a small amount of oil in cylinder and pull it thru a few times , this should seal up the rings again , put in a new sparkplug, and try normal cold start, you may have to clean the plug a couple times before it runs. if it runs but lacks power my guess is the rings got to hot and lost their temper or scored the cylinder. dont use alcohol blended gas this will ruin fuel lines , they soften up and fall apart etc. premium regular if you can get it, check the fuel line to be safe for pinholes as they will **** air and not start if you get alcohol blended gas. anyway good luck. geo_1
Dec 08, 2008 | Poulan PP4218AV 18" Chain Saw
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
