Question about Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair
'clunking' sound is there an adjustment to eliminate the 'clunking' sound when driving my Jazzy at normal forward speeds?
  • 175 Answers
Yes, try removing the cat you ran over last week.
Actually, the clunking could be several things. First, check to make sure that the nuts holding the wheels on are very tight. If they are pneumatic, check the tire pressure to see if it is at the proper level. If they are flat-free, these tires won't have valve stems and have a semi-solid core instead of a tube. Chairs that sit in one place over a period of time will develop a flat spot on the tires. Usually, if it hasn't been too long, they will go away with driving and or warm weather and driving, otherwise, you need to replace the offending tire or buy some earplugs.
Posted on Jan 08, 2010
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
Just to add to "oregoon" answer, if the flat free tyres have deformed and are the reason for your problem, rather than replacing at about 40 pounds each you can reform them by heating with a hot water bottle. take the wheel off the chair (but leave it on the hub) fill to about 2/3rds a hot water bottle with boiling water as you would if using for bed, put a tee towel around the wheel so as not to mess up the water bottle, put the water bottle around the area of the tyre that is deformed and let it heat for about 10 mins, when it has heated up remove water bottle, lie the wheel flat on the floor and place some thing flat on top (like a piece of board or something thick and flat that will stay flat and not deform as the weight is added) and then place some weight on that 10-20kg approximately try to place the weight evenly, let the weight reform the wheel to the correct shape. As it cools over about 20 mins it should reform to proper shape. If not then you will need to do the same but rather than weight you will need to shape it by hand.
If it helps please click the "YES" box
good luck.
Mark.
Posted on Jul 23, 2014
Jazzy goes fast in forward slow in reverse
It is supposed to. Forward you can see where you are going and normal steering applies. In reverse, you can't really see where you are going and it is only for backing up. Also reverse steering applies, so you turn left to go right, which is confusing for old folks, especially at speed. In Forward, the throttle should be responsive, slow to fast.
Feb 03, 2017 | Health & Beauty
My whell chair moves too slow going forward
The 1120 can come either of 3 controllers. Find the speed control and adjust it to your desired speed. If you have the Pilot Controller the speed dial knob is at the rear of the controller. Be sure to fully charge the batteries after each use and check all connections for tightness.
Mar 23, 2013 | Pride Mobility Products Used Jazzy...
2003 Chevy Malibu LS. The problem is an intermittent clunking noise that happens during turns, especially when going in reverse and at slow speeds. There is a single clunk during the turn, and another...
Most likely you have a bad drive axle, each drive axle has 2 universal joints and when they get worn they make a big clunk sound. Especially turning or going from forward to reverse.
Please take a moment and rate my answer.............Thanks
Dec 01, 2010 | Chevrolet Malibu Cars & Trucks
Dear sir yes i ment cv joint & no it does
CLUNK NOISE YOU HEAR IS WORN CV JOINTS.
May 26, 2010 | 2003 Saturn VUE
Makes aclunking sound sometimes down shifting is
Yes, a clunking sound is normal if it does it occasionally, not all the time. I'd check my clutch adjustment. If the clutch is dragging a bit, this makes the clunking happen more often.
Quick check of the clutch adjustment. Put the bike in low gear and pull in the clutch. Now hit the starter button. If the bike surges forward before it starts up, you need to adjust the clutch.
Also, make sure that you aren't running too much oil in your primary. Too much oil will make the clutch do the same thing as it would if it were dragging. Only enough oil to reach the bottom of the pressure spring in the clutch.
Dec 01, 2009 | 2003 Harley Davidson FXSTD Softail Deuce
2000 GMC Jimmy SLT 4wd, 65k miles, baby'd, driven
bad transmission, it will need rebuilding or replacement. sorry....hopefully this helps
Aug 16, 2009 | GMC Jimmy Cars & Trucks
Loud Downshift
My 2004 Sporty shift pedal is "notchy" especially when cold (allow 20-30 sec. of idle after starting) to allow time for oil to wet the shift forks and gear assemblies before shifting into first driving off. Also when down shifting, I usually do NOT use engine/trans gear braking on the street to save wear and tear on the clutch and running gear...brake pads are a lot easier (and cheaper) to replace over the long haul
Nov 20, 2008 | 2005 Harley Davidson XL 883C Sportster...
Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair Logo
148 people viewed this question
Top Heavyduty Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Heavyduty Health and Beauty Expert? Answer questions, earn points and help others
